Showing content with the highest reputation on 03/06/2026 in all areas
  1. Black92GS
    New Engine - Sputtering On Acceleration
    Wrong plugs altogether? Or correct plugs but gapped incorrectly? OEM plugs were always a requirement for these cars, and even 20 years ago, we had quite a few bad running engine posts where the fix was "replaced plugs with OEM". I've seen these things run nearly flawless on heavily worn OEM plugs with gaps closer to the 0.090" range...so I'm not sure the gap alone was the main issue.
  2. bluecalais79
    OIL LEAK - 1994 Cutlass LQ1
    DOUBLE UPDATE - some really great news to report here. I was hoping for this and it just might be coming true..........I have been monitoring the amount of oil dripping in my flat pan since the return of the car, and its getting less and less. It may just be this was residual oil already on places on the motor that were not able to be wiped off, and I just might something here, an almost non-oil leaking LQ-1. Even the wife noticed how well the car is running, and if she notices, now that can't be bad, can it...........
  3. BEN??? Had to look at your user name a few times. Holy shit man. Its been a few minutes! How've you been?!? If for whatever ends you can find the Bose specific speaker brackets they can accommodate a bigger speaker. If you're using a 6.5 round you could make an adapter plate and then use a block of wood or something to take up the space to the bracket. Though honestly some self tapping screws would make the quickest work of it.
  4. xtremerevolution
    Rear speaker issues
    Nevermind what I said. I just re-read what was posted above. The factory speakers on these cars must be some complete shit. Nobody these days bi-amps a DVC speaker with two entirely different signals. Sounds like the only way to correctly fix this problem is what has already been suggested, to buy a cheap and weak 2-channel amp like an old Coustic Power Logic Amp-160 for like $40 and amplify the fullrange signal. Then again, I never really believed in dumping money into rear speakers anyway.
  5. xtremerevolution
    Rear speaker issues
    A DVC speaker doesn't create a hole in a specific range of frequencies. What you're looking at is more of a multi-way speaker. A DVC speaker has two voice coils on the exact same cone, acting in conjunction, wired to a specific impedance together. Sounds like there are two terminals here and two independent coils on two independent cones. The question I have, is whether or not there's a low pass filter in the amplifier on what used to be the tweeter's output, or if the low pass is filtered by a capacitor on the speaker itself.
  6. hailukah
    Rear speaker issues
    No, that will not give full range sound! The amplifier is low-passed at around 100 hz or so. It is a subwoofer amp. The factory speakers played a dual role of full range and providing extra bass. Hooking up the amplified wires to a speaker only gives low bass. It does not give any midrange. There is not any midrange on the amplified signal. NO MIDRANGE. If you hook the amplified wires to a 6x9 and the other wires to a tweeter you will have deep bass out of the 6x9 and high frequencies out of the tweeter. There will be no midrange! No guitars, no voices, no snare drum. It will sound like crap. I have my speakers hooked up with only the amplified signal. There is only bass coming from my rear deck. Just like if there were only a subwoofer back there. There is NO midrange. Only bass. Deep bass. It is not some muddy sounding mix of bass and mid. I'm sorry for repeating myself so many times, but I don't want anyone to get confused and ruin a set of speakers or just otherwise be disappointed. To clarify some more... 1 set of wires provides amplified bass-only signal. Those wires are hooked up to one voice-coil on the 6x9. The other set of wires is a low-power, full range signal. It is hooked up to the OTHER voice-coil on the 6x9 AND the tweeter. Just like a regular co-axial speaker. The factory 6x9 has dual voice coils on the 6x9. The wires do not power only the 6x9 and only the tweeter. One set powers the 6x9, the other set powers the 6x9 AND the tweeter. The wires that power the 6x9 AND the tweeter are not amplified by the factory amplifier. Those wire simply pass through the amplifier and are only powered by the factory head unit. If you want full-range, powerful sound from a replacement set of 6x9s, you will have to add an amplifier and use the signal from the full-range wires as the amplifier's input. That's the only way I can see to do it.
  7. cutlassman
    SOLVED! It’s unreal, but the shop installed the wrong spark plugs! Gapped to 0.060” instead of 0.045”. I put the OEM plugs and it runs great.
