Showing content with the highest reputation on 02/05/2026 in all areas
Old to W body's, new to this forum
SuperBuick and one other reacted to AWBODYGUY for a topic
Good day, I have been a W body enthusiast since high school 04. In my student parking lot, we had a 93 Gran prix, 94 olds cutlass supreme, 94 cavalier z24, 95 monte, and my lumina z34. These cars were everywhere! My first car was a 94 lumina z34 (still have it). In 2012 I put a 4.9 PFI in it and it is almost complete. I just need to replace the rear suspension and odds and ends. I have a 99 Monte (needs some work), and I just picked up a decent (needs some work) Cutlass supreme. I am buying a new top for the cutlass on Friday. I want to get black canvass instead of the white (the car has black leather interior). They come in black, grey, white, red. What do you all think would be the best color? Just curious. Very few of these ole buggies still around (at least in my area). I thought I would join the forum to see what you all are up to (I feel very late to the party). I already have seen some super nice examples of these cars (nice job everyone!). Ill post more as spring hits and I can get them out, and work on them more. Also, not adverse to loading them up on the trailer for any meets that might happen. Thank you! Hope you all have a wonderful day!2 points -
OIL LEAK - 1994 Cutlass LQ1
94 olds vert and one other reacted to bluecalais79 for a topic
Thanks all for this. As of the moment the car is in storage do it will be a while before I can check it out, but I will say I get more & more confident this will be the cause. It has been happening for a long time. Form the day I bought this car in Oct., 1994, I always wondered where a quart of oil was going every 1000 miles or so. My money is on this as pictured above, it was probably badly sealed to begin with. And these things don't get better, only worse. I went in and checked my 2020 repair bills from when I had the intake manifold gaskets replaced. The mechanic also replaced the gasket for the part 10130955 as you see in the photo but no mention is made on whether the distributor plug seal was addressed so I am going to assume it was not. While it's a shame all that work that was done to the motor back then would have to be re-done just to get at what needs to be repaired, so be it. Even if I decide to get the rear head pulled to replace the O-ring rather than trying my luck with sealant, that's still way better than having the entire motor pulled. I might as well go the whole 9 yards and have both head gaskets replaced for a one and done job. I should be getting the car out of storage within the next few weeks, I'll keep all posted on how things progress, and thanks again, much appreciated!2 points -
primergray reacted to bluecalais79 for a topic
It's that time. The oil leak in the rear main seal of my 1994 Cutlass Supreme SL with the 3.4L motor has gotten so bad that it needs to come out for repairs. In addition to this being in need of replacement, I am going to have the oil pan gasket replaced as well, along with the 3 coils and the alternator while the motor is out of the car. In addition to that, is there anything else anyone can think of that should be replaced while the motor is out, as this would be a golden opportunity to get it done. The engine compartment will also be degreased to clean up the big mess this leak has been making. It does not need a timing belt, water pump, or any intake manifold work as this was all done 5 years and 10,000 miles ago and no issues here.1 point -
RPE1992GPSE reacted to 94 olds vert for a topic
1 point -
SuperBuick reacted to Psych0matt for a topic
I wanna see pictures of the Gran Prix, never seen one before! /s Welcome!1 point -
SuperBuick reacted to RPE1992GPSE for a topic
You're in the right place because we love our W-bodies here. Welcome!1 point -
94 olds vert reacted to GnatGoSplat for a topic
It's in the valley right by where the transmission and engine block are joined together. Oil will pool around the distributor plug (also called "oil pump drive") and run down the side right where the transmission mates to the block so where it drips on the ground looks very much like a rear main seal. An O-ring goes bad on it allowing it to leak. Shine a flashlight down there, and if there's oil pooled in that area, that's your culprit. Unfortunately, yes, it's blocked by the rear head. What most people do is lift it up as high as possible and clean it and the block as well as possible. Some sandwich a thin O-ring under it, others RTV it. My memory is hazy, but I think I may have done both. On my pic, high pressure oil-resistant RTV is the stuff kind of squishing out from under it. It's dirty because this was many years later, but it worked great. Official GM procedure is to pull the rear head, but that's way, way too much trouble.1 point -
3100->3400 swap
92Lumi reacted to Nas Escobar for a topic
If you use your resources correctly, you can get a 3800 for the same price as the 3400. The smart thing would be to look for an S3 and then get an S2 UIM to make it all work. Anyways, the flywheel between the engines are the same. Both used the same 4T65-E trans. The motor mounts should be the same as well. My understanding is that the blocks are the same but the internals are what differentiate them from a 3.1 liter and a 3.4 liter.1 point -
Swapping 2.8L for 3100
92Lumi reacted to 1QUICKHATCH for a topic
Use the trans that is in the 88 and the ecm from the 2.8 as well. If the 95 doesn't have the coolant temp sensor for the Guage/light in the rear head you will have to install a 3 wire temp sensor where the 2 wire is. The throttle cable from the 95 is needed as well. If your '88 has a 3spd you will have to rig up a kick down cable linkage on the throttle body some how. I welded a bracket to the throttle body myself, wasn't perfect but it made it drivable. Sure there may be some other things that I'm missing since it has been about 6 years since I swapped my old lumina!1 point -
3100->3400 swap
92Lumi reacted to j_mezz for a topic
Welcome to the site - are you thinking of an entire engine swap or just the top end swap? I won't have any answers for you on that but in reading your post I wasn't completely clear. As for the rear suspension, I've been looking into this matter myself recently. Everything on my car related to rear suspension and brakes is rusted beyond recognition (but somehow the body is totally solid!). These two writeups have been Very helpful to me as I've been feeling my way through what my next steps should be... converting to rear coilovers: http://www.w-body.com/showthread.php/37622-Coilovers-Adj-Mounts-Solid-Cradle-Bushings-UPDATE-3-25-Design-Done%21%21%21%21?p=651227&viewfull=1#post651227 and swapping in aluminum knuckles and bigger brakes: http://www.w-body.com/showthread.php/46209-Bob-and-Rob-s-Gen-2-Aluminum-Rear-Knuckle-and-Brake-Upgrade-How-To-with-Pics1 point -
3400
the last 2 3400 swaps I did used 3.1 injectors on stock obd1 ecm's and they both run fine. the bigger injectors will make more power with a tune, but the first thing I would do is start with a better fuel pump. when I first put the 3100 in my old 84 cavalier I went to the track then swapped to a Camaro LT1 fuel pump and went back the next weekend with no other changes an dropped almost 4 tenths off my ET. if I was doing a basic (stock) 3400 swap on a obd1 car I would use 96-99 3400 or 3100 injectors with matching fuel rail (2000+ injectors will not work on stock ecm) or 2.8/3.1 injectors with a 2000+ 3400 fuel rail that has the higer pressure regulator. But if I was mooding a 3400 and dropping it in I would use injectors sized for the fuel requirements of the engine and a full tune.1 point -
3400
you will need: -throttle cable and bracket -upper rad hose -coil bracket and module -front pass. side engine mount bracket -ac compressor (not sure if the orginal one will work) -power steering pump and H/P line -brake booster hose all from a 3100/3400 w-body You can get away with running it on the stock ECM as long as you use the stock fuel injectors and injector harness from the 3.1. You will need to change (or have one made up) front pipe/ down pipe to hook up to the rear 3400 exhaust manifold. A 3 wire coolant temp sensor and connector from a 92+ 2.2L Cavalier is the easy way of hooking up your temp guage wire from the rear head on the 3.1\ you will also need a lower rad hose for a 92-93 3.1L w-body The wiring from the coils gets re-routed to the rear of the engine from the front... then its little things like coolant hoses, and vac lines. That is all that I can think needs done right now, but I am sure I am missing a few things.1 point -
3.1 to a 3.4 i want power?
you need the front passenger side block mount. your ecm will work fine. you will most likely need rad hoses from the 3100 w-body as well. The engine just get any 96 and up 3400, the 2000 and up tend to be better. Its best to get one from a grand am or other car cause that will give you the proper throttle cable bracket on the throttle body.1 point -
keep it simple and just bolt in the 3400 its less power than the TDC but less weight too! I would just use the stock tranny to keep cost down. you will need the front pass. side block mount from a 3100 equipped w-body because the bolt holes are in different spots, at least just on that spot of the block. use a coolant temp sensor from the 3400 (3-wire ) and wire up the temp guage to it insead of the back head cause the 3400 has no hole for the sensor. you will also need a throttle cable and exhaust manifolds for a 3100 w-body. Most people use the 3.1 injectors and harness when they do the swap untill they go to tune it. stay away from the '04+ 3400's in the equinox (I beleave it is) they have a plenum that faces the opposite way and a different crank sensor pick up on the crank that will not work with your 3.1 ecm. that is all that is comming to mind right now.1 point -
MPFI to SFI
92Lumi reacted to ToroToro for a topic
The '93 3100 used the exact same ECM as the 94-95 models.1 point -
MPFI to SFI
92Lumi reacted to OldSkoolGP for a topic
I was the one doing that swap, and if you're going to run a 3400 it's definitely worth it. You don't want puddle fuel injection on a 3400. The hardest part in your case would be repinning the C100 connector to your car's pinouts. Also, if you plan to use the same tranny you have now, that will require doing wiring changes on the harness, or you can just use the tranny for the 3400, and you're set. There really wouldn't be much more beyond that. Mine was a PITA because I had to convince my ECM that it's controlling a tranny when it is in reality a 5 speed.1 point
