Showing content with the highest reputation on 01/20/2026 in all areas
  1. Luminator98
    New member with 98 lumina
    Hi, I’ve just stumbled onto this forum, and i figure I’ll probably need to post here eventually acquired my luminator last year, 2nd owner from a grandma. 70000 (got w 55000)miles. Here’s some pics; thx yall
    4 points
  2. rich_e777
    Looks very similar to a few buildings in Nashville so had to ask.
  3. Luminator98
    Thank you(I hope I replied to your comment the right way) will definitely taking care of her best I can. As per my city; I’m located in Philadelphia.
    Welcome! I remember when those were your everyday generic GM car back in the day (`99-`04ish) but they really stand out now. 70,000 is great mileage considering the age and the only real problem spot on that 3100 is the LIM gaskets. Flush the fluids and keep the oil changed regularly and there`s no reason you couldnt see 200k on the OD if there isnt any rust. It looks like a brand new car from the pics, and that makes it extremely uncommon to rare nowadays. Great pics with the city background. What town are you in?
  5. White93z34
    Welcome to the forum. That should be a good reliable car!
  6. Here is info for the the swap based on my own experience of swapping my 88 cutlass w-body. 3800 swap w-body From 98/99 Monte Carlo z34/lumina LTZ with 3.8NA Needed - power steering lines (buy new) - Heater hoses (buy new) - Exhaust downpipe (or have one made) - AC system - all lines/parts from the engine bay (compressors can be from the gtp too) Best to have from the Monte Carlo/lumina but not mandatory - engine bay wiring harness - Cv shafts (buy new if you don’t have them) From gtp donor - motor - Trans - Trans cooler lines - rad hoses - Motor mounts - Cv shafts - PCM - Engine bay wiring harness Notes: cv shafts if using an HD trans you need to use the gtp passenger inner with the 1st Gen shaft and outer joint. If you get them from the Monte you can use the stock Monte drivers side. Wiring: if you can’t find the Monte Carlo harness you can use the gtp harnesss, and merge it into the 1st Gen c100 connector. With the Monte harness it comes with the c100 you just need to remove a few pins around and overall much easier but can be hard to find. You’ll need the GM service manuals for your donor harness and your original car to match the c100 connector. If using a Monte harness you will probably want to add the BBV wiring. This will also convert the car to obd2 PCM: you will need to get the vats/security removed(it’s possible it won’t be an issue but be aware it probably will be) and probably want to remove a few other codes. Rad: you could use your original, but the donor gtp rad will be bigger and fits into the chassis. I’d say it’s recommended but not 100% necessary.
  7. Black92GS
    L67 swap A/C
    One thing to be careful of there is that 2004 was a bit of a transitional year. A 2004 Lacrosse is a 3rd gen W and came with the 3800 series 3, while the 2004 Monte/Impala was still a 2nd gen and came with the 3800 series 2. Compatibility wise, you’re very much going to be stuck running a compressor compatible with a 2004 Monte SS if you want any hope of things functioning properly. The other potential gotcha is that 2nd gens also ran a BCM. There is a possibility that the PCM requires input from the BCM in order for the AC compressor to run correctly in the first place.
  8. 55trucker
    L67 swap A/C
    Ok, that's a start, that PCM is programmed to control a CVC compressor, (compact variable compressor), did you pull the supercharged powertrain from the same 2004 Impala vehicle including that compressor?
  9. 55trucker
    L67 swap A/C
    Putting all of the *hardware compatibility* aside for a moment.... what ECM/PCM are you using to drive that L67? Are you using the 1227727 case or the 1614936 case?.........with a burned chip tune for an eeprom These are OBD1.. or are you using an OBD2 pcm?
  10. 55trucker
    L67 swap A/C
    I'm going to differ with you on this Kyle....... what OP needs is the necessary A/C piping from a 1st Gen Regal with the 3.8 engine. If you intend on keeping as much as your car is currently fitted with you'll need the a/c compressor manifold hose assembly that was fitted to the 3.8 Regal & a new rebuilt pre 94 compressor. Everything prior to 94 is R12 based, everything post 93 is R134 based. When GM introduced 134 in 94 they changed ALL of the A/C line fittings thread pitch so NOTHING from prior & post can be used together. My suggestion to you is to keep your 92 car all 92, get that old 92 3.8 manifold hose assembly & purchase a new *rebuilt* pre 94 A/C compressor, even the manifold hose assembly changed in 94 because GM redesigned the back end of the compressor housing for 94 so the old manifold hose will not attach to the newer design compressor housing. Purchase yourself a new receiver/dryer as well as a new orifice tube. Go into Rockauto, search 92 Regal, they still house most of what you'll need.
