Showing content with the highest reputation on 12/13/2025 in all areas
  1. pwmin
    Actual Dyno CHARTS.
    The Monte. This was a long time ago and it's putting out less now for sure.
  2. Vegeta
    Actual Dyno CHARTS.
    3.5l LZ4 with an F23 in a FWD race car. Port work, WOT-Tech VVT Delete with Big Race Cam Kit. 75mm Throttle Body, Megasquirt MS3X. All credit to Dan @ R&R Motorsports for putting this together and sharing the results.
  3. Series8217
    Actual Dyno CHARTS.
    1993 3.4 DOHC in an 88 Fiero with a Getrag 282 5-speed. The graph says "Flywheel horsepower" but we set the correction factor to "1.0" which means no correction, so this is at the wheels. The 10ft-lb torque dip corresponds to a bad AFR there; I still have to tune it. Engine details: 1993 3.4 DOHC, balanced and blueprinted... Ok, more details: 91 Beretta iron flywheel (16 lbs), Sealed Power hypereutectic pistons with coated skirts, balanced rotating assembly, .030" overbore, honed with a torque plate, exhaust valve guides tightened up a bit, opened the bottom ring gaps to prevent flutter, gasket matched the lower intake manifold, custom upper intake manifold (shorter runners, direct shot from the TB to the runners), stock throttle body, stock ECM, stock injectors, stock cam timing, 3" cold air intake with K&N cone filter, 2.5" exhaust with Magnaflow cat and Spintech muffler. Pic so you can see the intake setup:
