Showing content with the highest reputation on 12/03/2025 in all areas
    1995 Monte Carlo No Heat
    You should be able to get at both sides of the heater core...return is at the front of the engine, that long steel piping that follows along the right side frame rail that sweeps upwards to the coolant pump manifold, the inlet side is right beside the brake vacuum booster, a short hose that passes overtop of the master cyl reservoir slipping over the steel supply pipe from the bottom of the thermostat housing.
