Showing content with the highest reputation on 10/15/2025 in all areas
  1. Black92GS
    Which Turbo GP stays and which goes.
    Just my $.02....The one you enjoy driving the most is the one you keep. There is something to be said about a mechanically sorted, but less than visually perfect vehicle that you can simply jump in and drive without worry. As much as I hate to say it, any 1st Gen W that isn't a total beater is relatively rare these days. Individual rarities within that are almost irrelevant when it comes to market value of these cars and I would go for the colour combo I like better, rather than the rarer combo every single time.
  2. GnatGoSplat
    If you like red better, I'd say keep the red. At least, from my POV, color is very important and I really like black. I know it's boring, but as an adult, I've only ever bought black cars as I like it so much. I'm not so big on rarity either, and I think you're right that the tan interior goes pretty good with the gold wheels. If you're not as hung up on color as I am, the next thing I'd find important is the body, more specifically, body parts that you can't easily swap like quarter panels. Does one have previous body work on a quarter panel, body filler, etc. while the other has clean original quarters? Body fillers might not give you any trouble for many decades if done well, just a skim coat, and stored indoors. I just feel like there's a lot of value in a really straight car. Other considerations, how much unobtainium do you still need for each car? Do you have the time to get the black one running, or will you get to it "someday" - but "someday" just never seems to get here (that's the story behind all my projects ).
  3. rcLord510
    Jiggity getting a turbo first gen?!?!
  4. White93z34
    Here's a picture from back when the black car was in better days.
  5. pwmin
    If you like the red, keep the red one. It will be easier. I would go the torturous route because I would want the black/gray cloth one. That is what I want if I can find one. Or maybe the red one and swap to the gray cloth.
  6. jiggity76
    For me, definitely the Black one. It being Black...and having Medium Slate Gray cloth, that is uber rare in the TGP World. You know me, rarity is a big deal and that one is definitely incredibly rare and sought after. I firmly believe that even though it's not in the better shape, you'll regret selling it later.
  7. GtpKo
    Actually its been holding up great. I've got over 20k miles on the swap now over 2 years. Nothing major, a couple ripped cv boots which may be because they were junkyard sourced. I highly recommend adding a HTOB spacer. ZZP sells them for around $50. Sits behind the HTOB and moves it closer to the clutch by 1/4" for earlier engagement and longer life. Aside from engineering the trans mount, the hardest part is getting the clutch pedal mounted and situated. The pedal arm needs to be cut & welded into proper position as well. As far as the mount, the low-profile mount I fabbed up works great. Only modification I made was adding rubber bushings under the nuts at the bottom to further insulate the mount from the frame. On an aluminum subframe, it might have to be done a bit different. Might be able to drill two holes and bolt it in the same way, but I haven't been hands-on with an 04+ subframe so I can't say for sure. I'm not a fan of the modified 4T65E bracket method that requires tubular control arms as the mount sits outside the frame. An extra $650 that could be spent elsewhere. There really are half a dozen ways you could fab up a mount but I can say for sure the one I made does the job. 3/16 steel plate holds up well so far. I have also just finished taking the time to document the changes to the tune that are highly recommended for a manual swap: Idle speeds in-gear changed to match P/N as its going to be wired to be in D at all times now. ( I actually added a toggle switch to change between forcing it in D or P, since P is needed for a crank relearn procedure if you need it) DTC codes changed And finally zeroing out all the auto trans stuff:
