Showing content with the highest reputation on 09/06/2025 in all areas
    TGP hood vent repair.
    Thank You Needed a win, its been awhile.
  2. rich_e777
    All that work and I ended up dropping and breaking that vent awhile back. Thanks to an extremely generous member here I have a replacement vent. I keep the pair inside packed in a box so I can`t break them without effort. Had an idea and went with it in securing the drip pans and screens. Using some things I had on hand I came up with some brackets that can be removed easily for cleaning or paint. I don't know if it helped or not, but I also used a small wire brush to clean out the posts and put a few drops of silicone lube in them before barely snugging up the mounting screws. Everything holds tight and secure when the hood is open and closed and looks good from the top, underneath maybe different but each side is mirrored to the other to the 1/16" with the exact same parts. It could look better with fabbed up metal stock instead, but the idea works and can be covered with some insulation in the future. It really doesnt look half bad with just the screens and pans, and Ive not even painted those yet. Seems like it could match the front grilles...
  3. Quaraxkad
    L67 Swap PCM issue
    IT RUNS!! Someone on another forum provided me with a newer program version for my PCM with VATS disabled in their software. I flashed it, and the car finally stays running!
  4. 55trucker
    L67 Swap PCM issue
    Where in the 98 Lumina harness is the pin location to the PCM for that circuit? your schematic doesn't display it
