  2. Crazy K
    Crazy K
      10,019
      5,381
  4. Black92GS
    Black92GS
      146
Showing content with the highest reputation on 08/31/2025 in all areas
  1. Crazy K
    90-94 Lumina Cluster Pinouts
    I substituted a 1991 euro cluster with oil pressure gauge in place of a regular cluster. The project vehicle is a 1992 lumina sedan. However, I have also dismantled the voltmeter (no oil-gauge) cluster and input the info I discovered on it as well. The info here can help you to make any lumina cluster work. Disclaimer: I don't know if the all 90-94 base clusters are identical, please check this against your wiring, before you start. 1990, 1991, and some early 1992 Euro rally clusters have oil gauges. all other 1992, 1993, and 1994 have voltmeters replacing the oil gauge. Their are 14 seperate clusters used in Luminas that I am aware of: 1990 base cluster: thin lined monstrosity, with a light gray background 1991 - 1994: base cluster with a black ground 1990 gauge cluster: thin lined monstrosity with oil gauge and tach 3.1 redline 1991 - mid 1992 gauge cluster with oil gauge and 3.1 tach redline 1991 - mid 1992 gauge cluster with oil gauge and 3.4 tach redline mid 1992 - 1994 gauge cluster with oil indicator, charge gauge and 3.1 tach redline mid 1992 - 1994 gauge cluster with oil indicator, charge gauge and 3.4 tachredline and then each of those is available in english and metric specifications. GEEZ!!! the shift indicator, or filler plate, is interchangeable between all the clusters. I repinned my own connector. with practice and a good narrow jewelers screw driver it's quite easy. Just remember to tweek the lock tangs to ensure they lock when you reinsert. I would snatch an extra instrument cluster pigtail before starting and practice depinning and reinstalling. I emptied an extra connector and transferred the wires one by one to prevent confusion. Additionally, this swap requires a new temperature and oil pressure sender (if oil gauge cluster) in place of the original switch. The harness connectors are identical. Remember the length of the oil sender for the gauge is about twice as long as switch for the base cluster. The top row is C, bottom row is D and they go 1-16, left to right. For the Base Cluster First number is the base cluster pin location. Then the wire color and description. The last number is where it has to be moved to in the euro cluster harness. 1990-1994 Lumina cluster base connector Pin# Wire color function bc-C1 --- not used bc-C2 --- not used bc-C3 PNK/BLK switched ignition feed, hot in run (+) D4/D11 bc-C4 YEL/BLK Low Coolant indicator C16 bc-C5 TAN/WHT "Brake" Warning indicator D13 bc-C6 BRN charge indicator C15 bc-C7 DK GRN Coolant Temp indicator C7 bc-C8 --- not used bc-C9 BLK Ground C2/D6 bc-C10 BRN/WHT "Service Engine Soon" indicator D16 bc-C11 --- (low fuel indicator if equipped) bc-C12 LT GRN/BLK "ABS" indicator D13 bc-C13 PPL Fuel Gauge input from sender C5 bc-C14 --- not used bc-C15 --- not used(low oil, if equipped) bc-C16 LT BLU Left Turn signal indicator C9 bc-D1 TAN Oil Pressure Indicator(grounds to light if no pressure) C13 bc-D2 YEL Fasten Seatbelt indicator(grounds to light) C11 bc-D3 --- not used bc-D4 --- not used bc-D5 --- not used bc-D6 --- not used bc-D7 --- not used bc-D8 GRY Illumination (adjustable backlighting) C3 bc-D9 --- not used bc-D10 --- not used bc-D11 --- not used bc-D12 BLK Ground C2/D6 bc-D13 DK GRN VSS speedometer input D5 bc-D14 --- not used bc-D15 DK BLU Right turn signal indicator D1 bc-D16 LT GRN High Beams indicator D2 Ok, here is the pinout for the Euro's fully instrumented cluster. First number is the base cluster location. Then the wire color and description. 1990-1994 Lumina Gauge cluster connector Pin# Wire color function ec-C1 ????????????????TAN/BLK possible shift indicator(if equipped) ec-C2 BLK Ground ec-C3 GRY Illumination (adjustable backlighting) ec-C4 --- not used ec-C5 PPL Fuel Gauge input from sender ec-C6 --- not used ec-C7 DRK GRN Coolant Temperature gauge input from sender ec-C8 --- not used ec-C9 LT BLU Left Turn signal indicator ec-C10 --- not used ec-C11 YEL Fasten Seatbelt indicator ec-C12 --- not used ec-C13* TAN Oil Pressure sender(oil pressure gauge cluster) ec-C13* --- not used (voltmeter gauge cluster) ec-C14 --- not used ec-C15 BRN Charge indicator ec-C16 YEL/BLK Low Coolant indicator ec-D1 DK BLU Right Turn signal indicator ec-D2 LT GRN High Beams indicator ec-D3 ????????????????TAN/BLK (if equipped) shift indicator (if present) ec-D4 PNK/BLK switched ignition feed, hot in run (+) ec-D5 DK GRN VSS speedometer input ec-D6 BLK Ground ec-D7 --- not used ec-D8 --- not used ec-D9 WHT Tach Signal (analog) ec-D10* TAN Oil Pressure indicator(voltmeter cluster) ec-D10* --- not used (oil gauge cluster) ec-D11 PNK/BLK switched ignition feed, hot in run (+) ec-D12 --- not used ec-D13 TAN/WHT "Brake" Warning indicator ec-D14 --- not used ec-D15 LT GRN/BLK "ABS" indicator ec-D16 BRN/WHT "Service Engine Soon" indicator *difference in wiring reflecting the oil pressure to voltmeter revision. Make sure you hook your wires up correctly. Connector matching: ec-C2 BLK Ground bc-C9 or bc-D12 BLK Ground ec-C3 GRY Illumination (adjustable backlighting) bc-D8 GRY Illumination (adjustable backlighting) ec-C5 PPL Fuel Gauge input from sender bc-C13 PPL Fuel Gauge input from sender ec-C7 DK GRN Coolant Temperature gauge input from sender bc-C7 DK GRN Coolant Temp indicator ec-C9 LT BLU Left Turn signal indicator bc-C16 LT BLU Left Turn signal indicator ec-C11 YEL Fasten Seatbelt indicator bc-D2 YEL Fasten Seatbelt indicator(grounds to light) ec-C13* TAN Oil Pressure sender(oil pressure gauge cluster) ec-D10* TAN Oil Pressure indicator(voltmeter cluster) bc-D1* TAN Oil Pressure Indicator(grounds to light if no pressure) ec-C15 BRN Charge indicator bc-C6 BRN charge indicator ec-C16 YEL/BLK Low Coolant indicator bc-C4 YEL/BLK Low Coolant indicator ec-D1 DK BLU Right Turn signal indicator bc-D15 DK BLU Right turn signal indicator ec-D2 LT GRN High Beams indicator bc-D16 LT GRN High Beams indicator ec-D4% PNK/BLK switched ignition feed, hot in run (+) ec-D11% PNK/BLK switched ignition feed, hot in run (+) bc-C3% PNK/BLK switched ignition feed, hot in run (+) ec-D5 DK GRN VSS speedometer input bc-D13 DK GRN VSS speedometer input ec-D6 BLK Ground bc-C9 or bc-D12 BLK Ground ec-D9 WHT Tach Signal (analog) must add from c100 or ICM ec-D13 TAN/WHT "Brake" Warning indicator bc-C5 TAN/WHT Brake Warning indicator ec-D15 LT GRN/BLK "ABS" indicator bc-C12 LT GRN/BLK "ABS" indicator ec-D16 BRN/WHT "Service Engine Soon" indicator bc-C10 BRN/WHT "Service Engine Soon" indicator *wire to match your donor cluster as needed. %the base cluster wire must be spliced to feed two connectors on the euro cluster. Not used: ec-C1 ????????????????TAN/BLK possible shift indicator(if equipped) ec-D3 ????????????????TAN/BLK (if equipped) shift indicator (if present) bc-C1 --- not used bc-C2 --- not used bc-C8 --- not used bc-C11 --- unused "low fuel" indicator bc-C14 --- not used bc-C15 --- not used(low oil, if equipped) bc-D3 --- not used bc-D4 --- not used bc-D5 --- not used bc-D6 --- not used bc-D7 --- not used bc-D9 --- not used bc-D10 --- not used bc-D11 --- not used bc-D14 --- not used ec-C4 --- not used ec-C6 --- not used ec-C8 --- not used ec-C10 --- not used ec-C12 --- not used ec-C13* --- not used (voltmeter guage cluster) ec-C14 --- not used ec-D7 --- not used ec-D8 --- not used ec-D10* --- not used (oil guage cluster) ec-D12 --- not used ec-D14 --- not used KEY: not used= no connection, no wire was present, if there is an optional light I listed it. (ie shift if equipped) For (bc-C3 Pink/Black - Ignition Power ec-D4/ec-D11) this power wire must be spit to have a second wire , as the base cluster has one socket and the full guage cluster has two. in a proper euro harness they link. For the tach, (ec-D9 White - Tach Wire, analog) this wire is absent from within the car. I discovered that the tack wire is a small gauge white wire in the harness that meets the firewall behind the alternator(the C100 connector). It does not continue past there into the body. Open up this wire loom and you’ll discover bunch of wires. Only about 5 are small gauge, and the white wire will be obvious. Link it from there and run it inside the car to the cluster. Be sure not to have it run where it will get damaged and shorted. Euro cluster ec-C13 and ec-D10 positions are two possible locations for the oil pressure wires. ec-C13 in for the guage, ec-D10 for the idiot light. This is the only know difference I have found between the two types of clusters. This is a possible difference, I didn't track this info very well, but Euro cluster D1 and C3 (ie Tan/Blk? ie shift indicator if equipped?) either appear to be possible locations where a manual trans car would have up-shift, or down-shift indicators. I didn't have a year break down for these, sorry. One last issue, some pins actually are identical to other pins, so a wire could be in a slightly different position (ie C7 instead of D7, fake example) this issue is usually the same number pin but different letter (ie C7=D7, or D13=C14, fake examples) This is visible on the back of the circuit board as the circuit line will run through both pins.
