  2. pwmin
    pwmin
      4,686
  3. White93z34
      10,792
  4. beachbons
    beachbons
Showing content with the highest reputation on 05/08/2025 in all areas
  1. Black92GS
    Whats the point of these strut “wings”?
    Apparently It’s called a spring plate. If I’m seeing things correctly, it seems like it’s used to attach to lower part of a spring compressor.
  2. beachbons
    Convertible top relays location 1995
    UPDATE; Thanks for everyone's help. Well, it wasn't the Relay. I traced a continuity issue back to the "Up/Down" switch on the console. Took apart the switch and found the metal "rocker" contact was shorter on the one end that was supposed to be contacting the "Down" side. I was able to manually jump across each contact to move the top "up" and "down", so, I knew everything worked; I just had to get the contacts closer. I bent the shorter end a little and it now makes good contact. I can't imagine how it became shorter; did it break on the end?...I don't know. I did put the piece under a magnifying glass and I asked my wife if she could see anything unusual about the piece and she immediately said, "one end is shorter" Here is a pic of the inside of the switch and a pic of the "rocker" contact.
