  1. mfewtrail
    mfewtrail
      5,979
  2. Breakdown
  3. Galaxie500XL
      5,382
Showing content with the highest reputation on 03/20/2021 in all areas
    LQ1 CPS.
    Yeah, I will have to save up probably.
  2. mfewtrail
    LQ1 CPS.
    If I were you, I would buy a multimeter(or two...one standard one, and one with a current clamp capable of reading DC amps) and a scan tool at least capable of reading engine data on those LQ1's. Both will pay for themselves many times over if you do your own diagnostic work. There's tons of documentation online these days to help you get started using either tool. If you want some recommendations for either, let me know(buying all the stuff I recommended would be far cheaper than a single dealership visit by the way).
    Coil packs.
    Pardon my *advanced age & the continual brain short circuits*......must be the prescription drugs I am on for the spinal stenosis..... what I should've explained is that the cylinder which is on the compression stroke receives the bulk of the discharge while the cylinder on the valve overlap receives a reduced coil discharge seeing as it does not require a * full squirt*, the magnetic cam synchronizer circuit looks after that.
