  1. pwmin
    pwmin
      4,711
  2. jake91
    jake91
      5,395
  3. MemphisMan
    MemphisMan
      1,553
      5,389
Showing content with the highest reputation on 02/24/2020 in all areas
  1. bluecalais79
    Cutlass Supreme - Door Latch Repair
    A lot of you out there probably already know this but I thought I'd throw it out there anyway. I'm currently working out a lot of the bugs that came with my 94 CS 2 door I just got back, and one of them is the age old problem of the B-pillar located door handles going bad. Good news. It's not always the handle itself. I replaced the handle mechanism on the Drivers side as it was broken (after spending a good amount of time bending it to get the right contour of the door) and it still didn't work. After looking top of the rod. at it further I noted there is a fitting nut that screws on to the top of that rod going into the latch. I turned it all the way to the top so the adjusting nut was flush with the top of the rod which had to be over 1/4 inch adjustment. PAYDIRT! The door handle now opens the door like it was when it was new! This worked so well I made this adjustment with my white 1996 CS and same thing, that car's doors now open like they should. Good thing, I was getting sick of crawling through the pass through in the trunk to get into the car. As mentioned I had to replace the Drivers Side but I avoided replacing the passengers side and the ones on my white 1996. Also, IMHO the door handles available from A1 are better than the Dorman handles you get from Rock Auto. I did a side by side, the quality is better. With the A1 handle I had no problem bending it to fit. I don't think doing that would work with the Dorman handles too well.
    Yes, for sure, I have also discovered this with my 91 CS coupe as well. I have also learned from others here, getting into the habit of not using the handle to pull the door open but using my left hand (I'm right handed) to reach up and pull the door open at the top of the door frame. Good to know about the A1 units, thanks!
