      8
      9,318
  3. Breakdown
  4. runt
    runt
      4,993
Showing content with the highest reputation on 02/14/2020 in all areas
  1. digitaloutsider
    Temperature issue.
    The only thing concerns me is that it's directly related to whether or not there's load on the engine. Either way, the coolant temp sensor is cheap; replace it and see where it gets you. Looks like the actual GM one is only $15 on RockAuto.
  2. Amanita
    Temperature issue.
    I wish my '96 looked as good as yours. If your car was a '96 as well it might be easy to diagnose with an obd2 scanner monitoring the coolant temperature, but my best guess is the gauge is starting to become faulty. How high does the coolant get in the overflow tank after you've driven it for a while? That might be the easiest way to check if you're overheating.
