  1. l67ss
      8
  2. Galaxie500XL
  3. GnatGoSplat
      9,362
  4. Psych0matt
      11,075
Showing content with the highest reputation on 10/13/2019 in all areas
    Rounded bolt on the water pump
    START with a six-point socket instead of your 12-point. (Wild guess: There's a lesson to be learned here.) (Second Wild Guess: The bolts have corroded to the casting, you're gonna need heat, and you'll be lucky if the aluminum is saveable.) I've removed lug nuts with those so-called "Turbo" sockets. They're tapered inside, with a "reverse-thread" machining that tends to pull the damaged fastener in, and wedge it as you turn the socket to loosen the fastener. The ones I have are specifically for lug nuts. SK sells some intended for general purpose. https://www.amazon.com/dp/B0007GGUEC/ref=psdc_553372_t1_B0007GGUE2
