Showing content with the highest reputation on 09/05/2019 in all areas
  1. quakerj
    '96 Grand Prix Project - new member
    Hi folks, I joined this forum at the suggestion of a guy on another forum regarding a '96 Grand Prix SE (150k miles) that I'm trying to fix up. I bought this car for peanuts knowing it had a bad head gasket (or worse.) With a cold engine and radiator cap removed, coolant shoots out of the radiator whenever the starter is engaged or engine running. There's evidence of coolant boilover out of the coolant expansion tank, plus coolant in two or more cylinders (wet plugs). Also have coolant in oil (not a huge amount, but enough to tell it's there). Idiot previous owner wired up the radiator fan to run all the time instead of fixing what was probably a simple intake gasket, and proceeded to overheat the piss out of it. I'm pretty confident it's head gasket and not just the intake gasket. Oddly a compression test gives me 170 PSI on all cylinders. Pretty major power steering leak and a small section of rotting brake line that needs replaced round out the list of problems with this car. Shouldn't be all that difficult to make a good runner out of this, I've done head gaskets and fairly major repairs on other vehicles. I will probably make another post inquiring about options for repair-- I'd really like to consider an engine swap. This is purely a project car, can take my time and do it right. But for now, just wanted to introduce myself and add a couple pics of the car. Have always loved this body style GP, didn't give it a second thought when I saw this for sale, I had to have it!
  2. Cutlass350
    Engine Support bar mounting locations
    Iirc, the Quad4 and the LX5 (3.5L V6) also have one or more lifting points. When I did the Quad4 head gasket and bearings, I had to remove the head. So, the lifting points also had to come off. :-P Btw, some times, the lifting brackets(if separate) may have been removed and not put back on. I did that on my Mustang, since the bracket was a PITA, and often in the way. For many older V8 Mustangs, it's rare to see the factory engine hoist brackets still on the engine. :)
  3. pitzel
    Don't know about the 3.4, but the 3.1 has lifting points which work decently well with the chains on the Harbour Freight support bar. This is the setup I used to change the oil pan gasket.
  4. el_corsez
    New guy from Belgium
    Here's an old picture that I have lying around. I'll do some higher quality ones once I get the car back. Still quite a lot to do with it, I've been stockpiling parts for some time now. I still need to find the passenger side rearview mirror glass. I found a NOS driver side complete assembly because mine is completely shot but can't seem to find just the glass for the right side.
