      14
      5,396
      9
      9,326
  3. Breakdown
  4. Galaxie500XL
Showing content with the highest reputation on 08/06/2019 in all areas
    Transmission Cooler Temperature
    It's not what I'd prefer to use, but lots of folks do, and clearly the cooler manufacturers use those fittings so they clearly have confidence in them. Given any choice, I'd stay the hell away from typical worm-drive clamps due to the damaged hoses they promote . "Fuel Injection" clamps work much better--if you can get them large enough. Be careful of the hose you use. Typical "fuel" hose is NOT appropriate. PS return hose works well if the pressure rating is high enough. Best bet is the push-lock style hose from the hot-roddy aftermarket like Aeroquip, Russell, etc. Done properly, you wouldn't need clamps at all.
  2. MemphisMan
    Remote Door lock reciever process not working 95 CSC
    Probably N/A at this point sounds like, but for whats it worth, my RKE module would not go into program mode (using the jumper) because the solder joints were bad in the module. I used a test light to verify I had power going to the RKE module. Once verified, I perfomed the RKE solder fix, then it would enter program mode. I know you have an aftermarket device installed, but you could still have a faulty RKE module, but not sure it matters at this point.
  3. Schurkey
    I don't know about 4T65E specifically, but typical trans cooler pressure is 30 psi to 80 psi. High pressure in the cooling circuit means high pressure in the torque converter--which means the crankshaft thrust bearing is in danger. The cooler return flow doesn't get dumped into the pan, that's what lubricates the geartrain.
  4. ManicMechanic
    Vintage W-body photo thread
  5. bluecalais79
    Windshield Wipers
    You are spot on for the 22 on the other side, it won't work. I kept a very watchful eye on the sweep and the 22'' on the passengers side won't come into contact with the drivers side but that's the extent of it. Beside, now that I'm back home I'll work on grabbing a set per Rich_e777's note. No sense in tempting fate with the current oddball sizes on the car now.
  6. W30olds
    Gave the ole girl a cleanup
    Wash/wax on my GP. Been neglecting my car for awhile. Decided to clean her up this evening. Sent from my SM-G900V using Tapatalk
  7. 1 point
