  1. oldmangrimes
    oldmangrimes
      258
  2. Galaxie500XL
  3. White93z34
      10,787
  4. Go4DaMo
    Go4DaMo
      1,083
Showing content with the highest reputation on 06/12/2019 in all areas
  1. Bake82
    Hypothetically speaking...
    Here's the info: Any 97-07 engine and trans combo will work. It's slightly easier 98-02. Here's what you need from the GTP donor car Motor transmission PCM Rad motor mounts axles Here is what you need from a 98-99 monte carlo Z34/Lumina LTZ as it originally came with a 3.8 and the wiring harness is very similar to the 90 GP. Engine wiring harness (C100 at firewall will need slight re-wiring to work in the 90 GP and add the BBV wiring(I think)) rad hoses tensioner, and heater hose fitters(they are at a right angle vs straight on the newer ones, but the newer ones can work). heater hoses power steering lines PCM mount/case Exhaust downpipe AC components, everything from firewall forward axles 97 is odd because of the transmission and vacuum hose routing. 03 is odd because of the transmission wiring. If you use a 03 transmission, you MUST use a 03 PCM. 04-07 has a GEN V supercharger, you'll need a throttle body adapter to use either an L67 TB or Northstar TB and LQ4 MAF. Whatever TB you use, you'll need to match the TB Adapter. Additionally if you use a 04-07 transmission, you MUST use the 03 transmission. Axles: If using monte carlo transmission, they should bolt in not issues. if using GTP transmission, take the inner tulips that plug into the transmission, and swap the rest of the 1st gen axle into those tulips. They will pop in with no issues, assuming the original 1st gen trans was a 4spd. If 3 spd, it won't work. If I had to do this again, I would find the 98/99 monte carlo z34/lumina LTZ and steal all of the parts from. I would then top swap the 3.8 and run it in the GP. Good luck with your swap!
  2. 95LQ1VERT
    95lq1vert's 1994 Cutlass Supreme convertible progress thread
    I put new mufflers and tips on recently. Mufflers are Total Flow 33225 from Amazon, pretty much Magnaflow knock offs. And the tips are 2.25" single inlet to dual 3" outlet. Sounds good, drones a bit at cruising speeds though. Link to my YouTube video below. Sent from my SM-N960U using Tapatalk
