Swapping out rod bearings without taking engine out
mycarsucks replied to mycarsucks's topic in Powertrain
has anyone else changed out the bearings with the motor in the car successfully? I cant find any other threads on this site, and I don't have the time or money to replace the engine. -
1995 Cutlass Vert - Assistance Identifying and locating part
JGP replied to JGP's topic in Cutlass Supreme Convertible
Take a peek at this picture, what is part #9? Almost would make you think it's this part that is attached to the glass - no? -
I will take a peek if I can see any print on the glass... I'd be curious if it was identical to the coupe as I'd probably have more luck finding a hardtop with a good glass than a convertible. Jiggity76, I'd be interested if your friend has anything - then I'd have to figure out the best way to retrieve it...Afterall, Iowa is a long way from Ontario Canada, lol. I may attempt a short term fix - perhaps colored epoxy injected into the crack...wonder if it's been tried. -
rich_e777 replied to JGP's topic in Cutlass Supreme Convertible
Can you see any small white print anywhere on the glass? Mines covered and its raining otherwise I`d check. Carlite will print part numbers on their glass and thats usually the factory brand used. Hopefully thats what the convertibles conversions used too... -
94 olds vert reacted to a post in a topic: 1995 Cutlass Vert - Assistance Identifying and locating part
IMG_8182.mov -
jiggity76 reacted to a post in a topic: 1995 Cutlass Vert - Assistance Identifying and locating part
jiggity76 replied to JGP's topic in Cutlass Supreme Convertible
Very beautiful car that's for sure! Unfortunately, that part isn't a separate part from the door glass. In other words, that rubber seal or gasket came attached to the door glass and was installed on the assembly line from GM's glass supplier. Whoever supplied the glass for our cars, that was included at their manufacturing facility. GM just gives a part # for the entire door glass and not just for that seal. I'm guessing you'll have to find a door glass with a good seal already attached, or somehow figure out how it's attached to the glass, and swap it over to your vert. It might be better to talk with a glass supply/repair shop or just swap out the entire glass with another one that has a good seal. GM's part # for the entire door glass is 10188181. That number isn't showing that any are available NOS anymore. Again, your only options are glass shops or a good used glass with that seal from a junkyard or parts vehicle. If you're interested, I might know a guy who has a stash of parts convertibles and he will more than likely have a good door glass with that seal. By the way, for 1995, only 338 cars were made in Bright Red, White interior, and White top. -
I have a 94 gp with what sounds like the beginning of a rod knock when the engine is warmed up, i know on a 3800 you can swap out the barings with the motor still in the car by pushing the top bearing around the crank journal and out. Is this possible with the 3100 and what do I need to do to take the oil pan.
mycarsucks joined the community
So sorry, here I am asking for help and I go off the radar. Here is the pic...it looks like it's attached to the glass actually. I've attached also a pic of the car - such as shame as everything is perfect on it, 13,000 original miles. Love to get this fixed. Sorry the pic looks so huge. -
Are the 2nd gens reaching a "collectors status" before the 1st gens are?
GranPrix posted a topic in General
Now that some of these cars (especially the 1st gens) are 30-35 years old, are these cars starting to go up in price? I bought my 95 prix at a buy here pay here lot for $1400 with 170k miles on it. I have seen multiple 97 and 98 GP's with 150kish going for 3 or 4 grand. One 97 GTP with low miles sold for $10K!! Meanwhile every once in a blue moon when a 1st gen comes up on marketplace, it is usually in between $1000 and $2000. Because the 97-03s seem to be going up in price one would assume that the 1st gens would also go up in price but it doesn't seem that way to me. The only "expensive" 1st gens I see are the McLaren turbo ones. The 2nd gen w bodies seem to be much better documented and well regarded than the 1st gens are. I believe it is because of how popular and well regarded the 3800 series II supercharged engine is, but I don't know. -
Rear convertible window weather stripping
Nick727 replied to 94 olds vert's topic in Cutlass Supreme Convertible
can you use hardware (bold and nut) to hold the new stripping on rather then riveting it back into place? -
Can't get the steering wheel controls to work with the Pac Swi-X controller
Nick727 replied to Dark Ride's topic in Car Audio
can someone post a link(s) or part #'s or the exact type for SWC adapter for my 93 cutlass. I'm having no luck finding one. Thanks -
Here's the before and after pics. The wiring harness adapter i have does not have the SWC on it. So I have to find one for it. Anyone have any leads on one? But everything else works great and sounds pretty good too.
I do have access to a couple wrecked impalas I just haven't ever gotten a good look at them to know if they'd be a direct bolt up or not. Another thing is I don't know how much work it would be. In my mind if im correct in assuming that they are the same bolt pattern from the subframe to car then it shouldn't be to much more work than a regular subframe swap, right? maybe a bit extra wiring and exhaust work but whatever.
Caster alignment on 1g w bodies
GranPrix replied to GranPrix's topic in Brakes/Suspension/Steering/Wheels/Tires
I know that caster doesnt cause tire wear, I was just implying that if the control arm is bent then the camber angle might also be off and might wear the tires. The shock towers at the top look slightly ovaled out towards the center of the car so i bet they did that to "mask" the issue like you stated. I cant think of anything else that could cause a bad caster angle on these, and my control arm is pretty crusty after 29 years of Minnesota weather (only reason its not in the junkyard from the rust is because the previous owner fluid filmed it frequently LOL) It doesnt pull on a "flat" road, and the caliper is fine. -
jiggity76 replied to GranPrix's topic in Brakes/Suspension/Steering/Wheels/Tires
Thank you. With my car being an Oklahoma car, no salt issues but I'm still going to replace it. -
55trucker replied to GranPrix's topic in Brakes/Suspension/Steering/Wheels/Tires
Caster won't cause tire wear, if the caster is out of adjustment the vertical angle of the axis is just *off*. If indeed this IS your problem then it's possible that somewhere back up the road the issue has been *masked* by a previous shop. You didn't state whether the vehicle actually pulls to the right on a flat road, is the right front caliper dragging? -
Yeah, that's it Greg, up here in the salt belt they are prone to rotting out if not coated to protect them. -
Ah yes, I know what you're referring to now. I was wondering why that section was so long and why it went all around the cradle. Interesting about the rack. I'm assuming my car has it's original rack at 153,000 miles but who knows for sure. I do have an NOS ready to go into the car so might as well use it. Since I'm in there, I'll replace the lines, seals, and pump as well. What's the point of having all these parts if they don't go to use. Thank you as always. This metal hard line that goes to the front of the cradle...that's what you're referring too right as the extended length piping? -
Seems like that may be the issue, but wouldnt it be wearing tires if it was bent? Thats the weird thing about this whole ordeal. Both the front 2 tires have the same amount of wear and they have been driven over 15k miles since I put new ones on (my commute is 100 miles a day) -
Well, if the car does have a slightly bent control arm the alignment rack SHOULD see that instantly. The wheel sensors will send the info to the processor, there will be an obvious left/right setback reading on the display, the arm would be bent to the rear inducing a lower than expected caster angle reading at that corner. -
I just replaced the right front hub as it was making a groaning noise and the caster issue is still there which is the reason for my post. I thought that replacing the hub would have fixed it. No play of the wheel in any direction when the car is not moving. Again, the steering linkages and the wheel don't have any "play" in them at all. But once the car starts rolling down the road, there is a little more play on right side than there is on the left. I am also curious about the control arm, it looks the same as the other side to me but it might be bent slightly, just enough to throw off the caster angle. I will attempt to check the alignment pins on the subframe when I get home. I also will try to ask my friend who works at tires plus If I can put my car on their rack after hours but I don't really want to pay $100 for an alignment if the only thing they can adjust is toe... -
Personally, get a decent set of tires on Before you get an alignment done. The PS return line is an extended length piping, there are two sections to it, the shorter section is at the ps pump, it feeds down the front of the engine, there is a flexible hose on the end that connects to the major return piping that then feeds around the subframe to the front portion in front of the oilpan, then back along the same route all the way back to the rack. It's the total length of the return line that acts as a cooler for the fluid. Without any more info on your steering components condition I'll say this........when these cars were new there were issues with the steering wheel having a shimmy when *on center*, our car wasn't free of this issue, when at 8,000kms the steering developed that shimmy. It went back to the dealer who on the 1st visit replaced the ps pump thinking that the relief valve was fluttering, on the 2nd visit replaced the rack thinking the pressure seals inside were defective, on the 3rd visit removed all of the extended return piping to shorten up the distance between the rack & the ps pump in an effort to settle down any fluctuations in pressure. Doing #3 solved the issue with the shimmy. But that doesn't necessarily mean that doing #3 first could've/would've solved the issue. -
If the subframe is misaligned that means it was lowered some time in the past or an impact moved it. There are alignment pins used to locate the subframe before one tightens up the fasteners. If one side is trailing then the opposite side would be leading. An alignment rack would see that. I'm more inclined to think that the lower control arm on the right side is off angle (damage). But before you condemn the arm or anything else closely check the right side wheel bearing to ensure it is not loose in any way. You have repeatedly said that right side feels as tho there is *play*. -
Yes, absolutely using power steering fluid. I actually flushed the system and bought some fluid from my local GM dealer. All I know is that I used power steering fluid, can't for sure say the previous owner did or not. Yes, the what I'm assuming original line is still there and unsure of the cooler. Can you elaborate please? I am getting a shimmy thru the steering wheel when going straight down the road at very low speeds like coming up to a stop light or whatever. I'm assuming it's the tires as they're extremely old and dry rotted. Pretty sure I have a broken belt in at least one of the front tires or maybe all of them. I only drive it thru town, never take it on the highway or Interstate as I definitely don't trust them at higher speeds. They're on the to do list after I get the front end parts replaced and aligned. -
I always assumed all w bodies were the same up front and just had different rear suspension. guess I'm wrong about that. Also, do 3100 PS pumps have flow restrictors like type II pumps do? If so, I want to swap a higher restricting flow restrictor for increased steering feel, If I remember there about $20 from turnonesteering.com
