  2. primergray
    Sitting 1995 Regal GS
  3. Today
  4. Black92GS
  5. Amanita
  6. 55trucker
  7. bluecalais79
  8. Yesterday
  9. 55trucker
  10. bluecalais79
  11. Last week
  12. pwmin
    1995 Monte Carlo No Heat
  13. ron350
  14. pwmin
  15. ron350
  16. 55trucker
  17. pwmin
  18. 55trucker
    Well, defrost is the default direction for all optional failures, as for the heat can you get your hands around the inlet or outlet core piping to feel what the coolant temp is? if the blend door is stuck closed so the inlet air bypasses the core that would deliver what you're presently getting. One can see the actuators if you pull off the instrument panel cover, they are right behind where the glove box is.
  19. Earlier
  20. pwmin
  21. pwmin
  22. pwmin
  23. White93z34
    Master cylinder 95 Cutlass
  24. PairsNPaint
    W-body Install Guides
    Bueller? Bueller?
  25. brock9334z
  26. GranPrix
    Check where your positive battery cable goes to the fusebox on the drivers side under the hood. It is common for the nut to be loose or the connection to be dirty and cause all sorts of weird electrical issues
  27. I am trying to replace the solenoid in my car with the radio on for a good 30mins, confused about how the solenoid replacements works (see this post). Without getting the solenoid replaced, but finally being able to get the car out of park, I decided to start the car but it won't go. The dash started to flicker and can hear the relay ticking. Weird electronic glitches started to happen, like turning the signal would flicker the radio button lights. Feels like something is shorting out but can't tell and not electronically inclined. After trying to start the car a few more times, the radio wouldn't even come on anymore and I'm left with just relay ticking. I am assuming the battery is dead. Before charging the battery back up and trying again, I am looking for help to understand where the short might come from during my disassembly: - I took off the front console panel with the cigarette cable disconnected - I had to adjust the steering wheel tilt to take out the front console panel out. I know the multi-function switch is already wonky because I am not getting brake lights unless I pull the switch slightly back. Could adjust the wheel tilt cause the multi-function switch to become worst? - I took off the center console, with the two small light bulbs unclipped and shift solenoid switch disconnected - I took out the radio (and maybe because I pulled too hard) found the power copper wiring fraying out. I pushed the radio back in with the wires exposed and maybe it touched some back metal plate and shorted? Beyond that, I don't understand how this process has caused these electronic issues.
  28. architect
    Shifting from Parking
  29. I honestly don't know if they're low drag or not. I've never seen anything referencing that in SI or anywhere. I did find in the meantime, a thread by Miko K where he uses a 2nd/ 3rd gen MC with a 1" bore and installed it in his Cutlass. The biggest difference being two line outputs instead of 4, but he T'd them on the car to split the 2 channels to feed the 4 corners.
  30. "Bigger" master cylinder bore = less hydraulic advantage. If you have low-drag front calipers, you NEED the OEM three-chamber, step-bore, Quick Take-Up master cylinder. But I don't know if you have low-drag calipers.
