55trucker started following 1995 Monte Carlo No Heat and Rear Speaker Change- 1994 Cutlass 2 Door
architect reacted to a post in a topic:
Well, defrost is the default direction for all optional failures, as for the heat can you get your hands around the inlet or outlet core piping to feel what the coolant temp is? if the blend door is stuck closed so the inlet air bypasses the core that would deliver what you're presently getting. One can see the actuators if you pull off the instrument panel cover, they are right behind where the glove box is.
GranPrix replied to architect's topic in General
Check where your positive battery cable goes to the fusebox on the drivers side under the hood. It is common for the nut to be loose or the connection to be dirty and cause all sorts of weird electrical issues -
I am trying to replace the solenoid in my car with the radio on for a good 30mins, confused about how the solenoid replacements works (see this post). Without getting the solenoid replaced, but finally being able to get the car out of park, I decided to start the car but it won't go. The dash started to flicker and can hear the relay ticking. Weird electronic glitches started to happen, like turning the signal would flicker the radio button lights. Feels like something is shorting out but can't tell and not electronically inclined. After trying to start the car a few more times, the radio wouldn't even come on anymore and I'm left with just relay ticking. I am assuming the battery is dead. Before charging the battery back up and trying again, I am looking for help to understand where the short might come from during my disassembly: - I took off the front console panel with the cigarette cable disconnected - I had to adjust the steering wheel tilt to take out the front console panel out. I know the multi-function switch is already wonky because I am not getting brake lights unless I pull the switch slightly back. Could adjust the wheel tilt cause the multi-function switch to become worst? - I took off the center console, with the two small light bulbs unclipped and shift solenoid switch disconnected - I took out the radio (and maybe because I pulled too hard) found the power copper wiring fraying out. I pushed the radio back in with the wires exposed and maybe it touched some back metal plate and shorted? Beyond that, I don't understand how this process has caused these electronic issues.
I honestly don't know if they're low drag or not. I've never seen anything referencing that in SI or anywhere. I did find in the meantime, a thread by Miko K where he uses a 2nd/ 3rd gen MC with a 1" bore and installed it in his Cutlass. The biggest difference being two line outputs instead of 4, but he T'd them on the car to split the 2 channels to feed the 4 corners. -
Schurkey replied to carkhz316's topic in Brakes/Suspension/Steering/Wheels/Tires
"Bigger" master cylinder bore = less hydraulic advantage. If you have low-drag front calipers, you NEED the OEM three-chamber, step-bore, Quick Take-Up master cylinder. But I don't know if you have low-drag calipers. -
The Monte is pretty simple and old school. All the warning lights are just regular 194 light bulbs. So I was just planning on removing the ABS light bulb and the EBCM. I was curious about the MC bore sizes, since bigger would typically be better unless I'm overlooking something.
