  1. Yesterday
  2. SuperBuick
    Louver position on the hood
  3. Last week
  4. Amanita
    Rough idle/ volt drop
  5. Jscott
  6. Earlier
  7. rich_e777
    Digi UB3 adapter
  8. 55trucker
    4T65E Range Selector Bracket
  9. phewop118
  10. 94 olds vert
    Digi UB3 adapter
    This thread is 15 years old.
  11. rich_e777
    Digi UB3 adapter
  12. The LQ1 timing stuff looks intimidating until it's laid out step by step. That video saves a lot of random forum digging.
  13. hazelspindle3
    New member with 98 lumina
  14. hazelspindle3
  15. calmspindle6
    New to this place. Hello.
  16. That video is one of those rabbit holes where you start with a tensioner and end up learning the whole LQ1 timing setup. Pretty handy to have around.
  17. covefinch9
  18. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  19. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  20. mossyelk
  21. briskshovel88
  22. pwmin
  23. Kdog
    charm.li free forever
  24. Jscott
  25. do i leave it white ,or do i use, the red line ?
  26. fern_anchor
  27. willowhammer2
    89 olds swaybar
  28. bluecalais79
    A/C Repair - LQ-1
