4T65E Range Selector Bracket
So today the bracket on the range selector on the outside of the transmission on my 03 Impala decided to separate from the shifter cable. The ball on the end of the bracket is gone and the cable will not stay on. Does anyone have recommendation on sourcing a replacement bracket? I cannot find a part number or any info online… thanks!
There's no *ball* on the end of the bracket, there is a ball on the end of the trans lever. It is screwed into the lever.
  • 1 month later...
Finding out that a quick visual glance isn't enough to fix a problem is a common theme, whether you're dealing with car parts or evaluating online platforms. Just as a part might look fine until you inspect the actual connection, verifying online credentials often requires digging past surface-level indicators to confirm the real details behind them.
I recognised the Curaçao name in casino footers but didn't really understand what I was supposed to check beyond the logo. While comparing top Curacao casinos on https://interacasino.com/licenses/curacao/, I also read the explanation of the licensing setup and realised the licence details needed their own check. That gave me a more useful approach than judging by the badge alone. I'm now looking for the operator's actual details and checking them against the regulator's records before treating a licensing claim as confirmed.
Those little ball studs seem to vanish from the catalog entirely. A used bracket from a matching 4T65E might be the only non-custom route, otherwise it turns into one tiny missing piece holding up the whole car.
Edited by umbersparrow414
