xtremerevolution Posted January 26, 2012 Report Share Posted January 26, 2012 Andrei, I had already read the entire thread when I posted that, thank you. And I don't really care. A $30 investment now sure beats $1000 at minimum for a new engine. Oil is CHEAP. I do not understand the arguing in this thread. When in doubt, change it. Its more the issue of misinformation. An oil change ever 1500 miles is a bit severe. If your oil really is in need of changing by that point, you have some more serious issues with your motor. Oil might be cheap, but not when you have to do it every 1500 miles. Not sure how many miles you drive a year, but for the typical person driving 10-12k a year, that's over oil changes, or $180 a year, not including the time spent. Quote Link to comment Share on other sites More sharing options...
skitchin Posted January 26, 2012 Report Share Posted January 26, 2012 Every 3,000 or x months, whichever comes first...can't remember if they say 3 or 6 months Quote Link to comment Share on other sites More sharing options...
urbex Posted January 26, 2012 Report Share Posted January 26, 2012 The old saying was 3 months or 3,000 miles. Quote Link to comment Share on other sites More sharing options...
skitchin Posted January 26, 2012 Report Share Posted January 26, 2012 I try and live by the 3 months/3,000 miles rule - I've seen plenty of people run oil waaaaaaay longer, but I still think 3,000 miles is the golden number, even with synthetic. I run Mobile 1 full synthetic, and I go against the motor suggestions running 10w30 in the summers and the recommended 5w30 in the winter. Quote Link to comment Share on other sites More sharing options...
urbex Posted January 26, 2012 Report Share Posted January 26, 2012 I change my oil every 3k because it doesn't get up to operating temp as often as I'd like. Like said before, I'd rather overchange it than ruin the engine. And since I don't drive very many miles a year, that's still only a few changes a year. Quote Link to comment Share on other sites More sharing options...
Addicted To Boost Posted January 27, 2012 Report Share Posted January 27, 2012 the motor suggestions running 10w30 in the summers and the recommended 5w30 in the winter. That's a terrible idea... not sure where you heard that. The first digit in the 5W30 multi-viscosity rating, "5" is what weight the oil acts like at room temperature. The second digit "30" is the weight the oil acts like at operating temperature ~210*F. You want a very low viscosity for startup protection when the engine is cold and the most wear takes place. The second number really depends on application. In our cars, there is no need to run anything more viscous than 5w30. Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted January 27, 2012 Report Share Posted January 27, 2012 I always run 10W30 in the summer and 5W30 in the winter. I use 5W in the winter for the startup protection in the cold, but I switch to 10W in summer because the low viscosity is not needed and 5W30 has more viscosity improvers. I'm sure 5W30 is fine all year round and probably viscosity improvers have gotten better, but years ago I had read it's better to have less viscosity improvers and 10W30 has less than 5W30. That, and avoid Fram oil filters, are probably the only "oil paranoia" things I subscribe to. Quote Link to comment Share on other sites More sharing options...
gr8shot Posted February 2, 2012 Author Report Share Posted February 2, 2012 Im on pace to put 30k on my cutlass in the first 12 months of owning it just commuting to work. Not counting errands and other stuff. That's $600 a year in oil changes if I changed it every 1500 miles. $225 if I change it every 4000 miles like I plan to. $180 @ 5000 mile changes. Spending even $75 for 3 oil analyses to find my best OCI is money well spent when a person puts on the miles that I do. If I find out I can safely go 5000 miles, even spending that $75 for analysis I still save almost $50 by going from 3k to 5k. Plus I have plenty of piece of mind (oil analysis) that my motor is in good shape. Seems like a no brainier for me. Sent from my old skool Droid Quote Link to comment Share on other sites More sharing options...
RobertISaar Posted February 21, 2012 Report Share Posted February 21, 2012 In our cars, there is no need to run anything more viscous than 5w30. i ran a couple bottles of 20W-50 for shits/giggles once in the 3100.... yeah, totally bad idea. you'll have ridiculous oil pressure at all times, but damn does it drag down the motor. I always run 10W30 in the summer and 5W30 in the winter. I use 5W in the winter for the startup protection in the cold, but I switch to 10W in summer because the low viscosity is not needed and 5W30 has more viscosity improvers. I'm sure 5W30 is fine all year round and probably viscosity improvers have gotten better, but years ago I had read it's better to have less viscosity improvers and 10W30 has less than 5W30. That, and avoid Fram oil filters, are probably the only "oil paranoia" things I subscribe to. FRAM = FAIL but we all knew this. and yes Shawn, less viscosity improvers to meet a certain rating is good, since they do wear out/deplete, causing the oil to thin out a lot less than it's original rating. best of all worlds: a cheap(yet still great) full synthetic. synthetics have significantly fewer viscosity improvers, along with a bunch of other benefits i'm not going to ramble about, since there is already plenty of info available already via google. however, finding the best synthetic for the money is almost as much art as it is science. and since it was mentioned, GM makes references to the older oil life systems going up to at LEAST 7500 miles, when driven in perfect conditions. 10,000? i've never seen it, but maybe a DIS on a testbench would be a good idea... and i double-checked the 95MC owner's manual: 7500 in normal conditions, 3000 in severe duty. Quote Link to comment Share on other sites More sharing options...
Schurkey Posted May 15, 2012 Report Share Posted May 15, 2012 (edited) Bringing this back from the dead. http://hbassociates.us/Oil_Analysis_1.jpg (Click on image to enlarge) While not directly applicable to a W-body, here's an oil analysis record from my Trailblazer with the 4.2 DOHC inline six. The form used specifies that the "Time on Oil" is in hours, but the figures are actually in miles. The far right column is the oil sample taken when we bought the vehicle at ~24,000 miles. I have no idea how long the oil was in there, or what brand of oil it is. Middle column is a sample taken with "typical" use for this vehicle. The Oil Life Monitor has typically allowed about 13,000 miles between oil changes. At that mileage, (13,000) this (Mobil 1 5W30) oil was still fit for further use. I use NAPA/Wix filters. First column is most recent oil change. In fact, the report showed up in the mail yesterday. I intended to dump the oil while on a trip to California/Arizona. I ran out of time at my Dad's place in California, and my Father-in-law in Arizona isn't allowed to touch a wrench at his retirement community or he gets thrown out for violating Park rules--so I just drove back home; exceeding the Oil Life Monitor's recommendation by about 1,500 miles. Even with 15,000 total miles since the last oil and filter change, and 117,000 miles on the vehicle...the oil is fit for further service (I changed it at the time the sample was taken.) I think I had to add two or perhaps three quarts in that 15,000 miles. Dumping oil at 3000 miles on a feedback-fuel-injected, overdrive-transmission-equipped vehicle in otherwise good condition and not operated under "severe" conditions is NUTS. Edited May 15, 2012 by Schurkey Quote Link to comment Share on other sites More sharing options...
pitzel Posted May 19, 2012 Report Share Posted May 19, 2012 (edited) Yup, precisely. I have run the past 100,000km on 2 oil changes. One at the 100k mark when I got the vehicle, and one at 158k when the LIM leaked and I had to re-do it. Now I'm just cracking 201,000km, on my second oil change. The engine was spotless internally when I pulled the LIM apart to do the gasket. After 58,000 km (36,250 miles) on Mobil-1 and Esso XD-3 0W-30. The whole idea of changing oil, IMHO, is insane, especially when you have a filter to keep it clean. I do change my filters once every 15k miles or so. And keep the oil topped up. I bought 4x4L and 12 x 1L bottles (28L) of XD-3 0W-30, and if you subtract one full oil change (5L), I've consumed 13L. And most of that leaked out of the engine, with probably 3L just for make-up on the filter changes. So roughly 1L of oil consumption/leakage every 10,000km. Edited May 19, 2012 by pitzel Quote Link to comment Share on other sites More sharing options...
pitzel Posted May 19, 2012 Report Share Posted May 19, 2012 Schurkey, its too bad you weren't able to get TBN and oxidation numbers for the oils on the chart. Although I suspect that, in the 3.1L engines, as long as the coolant is kept out and the fuel system isn't badly out of tune, oil could literally last forever. Quote Link to comment Share on other sites More sharing options...
gr8shot Posted May 23, 2012 Author Report Share Posted May 23, 2012 I've got another sample that I need to send in. I just haven't had time due to getting married last weekend. Ill probably send it off next week. I went 4k miles again. If it comes back good ill stretch it out to 5k miles and probably stick with that due to the high miles on the motor. Its at 217k now and climbing quickly! I've put 20k on the car since late October Sent from my Droid using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
gr8shot Posted September 26, 2012 Author Report Share Posted September 26, 2012 Ill bring this back from the dead... I lost my last sample so I sent in a new one. I ran Napa 5w-30 and went 5500 miles on it. Results were flawless. Blackstone said to run to 7000 miles next time and send in an analysis. I can't post the actual analysis from my phone so I'll try to do it from home tonight. But it was all good news. The Napa uses some different additives compared to Valvoline which is surprising since they're both from Ashland. I normally run Valvoline but the Napa was on sale for dirt cheap so I tried it. I had been changing it at 4k miles and using the larger filter for the 3.4L v6 since its the same od and same threads, just longer so more capacity. I'm going to run to 6k this time and next time as well. Then ill probably send off another analysis and see how it comes back. I'm surprised that everything was good considering the motor has 228k on it! Sent from my Droid using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Schurkey Posted September 26, 2012 Report Share Posted September 26, 2012 I'm surprised that everything was good considering the motor has 228k on it! Feedback fuel injection and overdrive transmission...I'm not a bit surprised. Quote Link to comment Share on other sites More sharing options...
gr8shot Posted September 27, 2012 Author Report Share Posted September 27, 2012 Here's the recent analysis. So far so good!! Like I said, I'm going to shoot for 6000 miles or so for the next couple changes then I'll probably send in the next one. Going to do one on the duramax before the next one on the car though. Here's the link:Car oil analysis 9-26-12.pdf Quote Link to comment Share on other sites More sharing options...
rich17 Posted September 27, 2012 Report Share Posted September 27, 2012 How much did this run you? Ive been running Mobil1 for 6k-7l on my L26. I like the Mobil1 cause I tend to "beat" on my car Quote Link to comment Share on other sites More sharing options...
LuminaPower92 Posted September 27, 2012 Report Share Posted September 27, 2012 My cars usually get it every 5k or once a year since they never hit that 5k anyway. I usually run a Delco filter and Royal Purple. My wifes saab is the only one that sees more than 5k a year so thats about every 5 or 6 k with 0w20 sythetic, as per saab. Was using the shop sythetic at the saab dealer i was at, but ill probably go with royal purple with her's as well. Quote Link to comment Share on other sites More sharing options...
