Garrett Powered Posted June 27, 2011 Report Share Posted June 27, 2011 I want to see one of these bad boys in a w-body engine bay! NAO!!! Quote Link to comment Share on other sites More sharing options...
white4d96 Posted June 27, 2011 Report Share Posted June 27, 2011 I know someone with one in a van engine bay if that counts. Next time I run into him ill grab pics. Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted June 27, 2011 Author Report Share Posted June 27, 2011 I could put a jy unit on, but with a rebuilt one, I know it'll last a while without being a question of when. I guess it doesn't matter too much to me. I can change my alternator in 5 minutes blind folded and all of my alternators have lasted a very long time. This thread was more designed so that people can get a higher output stock fitting alternator for dirt cheap. Obviously anyone can spend the big money on a built alternator for their cars, but if I can get good mileage out of a junkyard alternator, I can spend the remaining money on something else. Quote Link to comment Share on other sites More sharing options...
Garrett Powered Posted June 27, 2011 Report Share Posted June 27, 2011 (edited) there is no cs130d's that will bolt on my car though, out of the JY. 2.8/3.1 guys need a modded case to make it a bolt in. What I should have done is made a thread and done a write up when I did that. Edited June 27, 2011 by Garrett Powered Quote Link to comment Share on other sites More sharing options...
white4d96 Posted June 30, 2011 Report Share Posted June 30, 2011 there is no cs130d's that will bolt on my car though, out of the JY. 2.8/3.1 guys need a modded case to make it a bolt in. What I should have done is made a thread and done a write up when I did that. Can't use the bracket bits off the D? Quote Link to comment Share on other sites More sharing options...
Garrett Powered Posted July 2, 2011 Report Share Posted July 2, 2011 if it is possible, I have not yet seen pics or even heard of anybody doing it. I would like to see someone try because then we might see more TGP's and other W's with D's in their engine bay. just like it would be nice to see more people running CS144's or similar chassis alts on 3100/3400 cars. or if someone installed the minivan bracket on a 2.8/3.1 and ran a big chassis alt, I would love to see if that is possible. you know how those alts have a split case though, so there is two sides. well, if you order a specially clocked case for the one side (wish I had a part number) and machine off some of the aluminum in a special way with a lathe, then it will bolt in on stock brackets. I bet you could use a grinder and get close enough but this shop I go to has no reason to take a chance with hand held tools. Quote Link to comment Share on other sites More sharing options...
LTZ Posted July 20, 2011 Report Share Posted July 20, 2011 the lumina LTZ comes with a 140 amp cs144 and it should be a perfect match even for the GTP's, i'm using it for my top swap Quote Link to comment Share on other sites More sharing options...
LTZ Posted July 20, 2011 Report Share Posted July 20, 2011 ok guys, sorry I just went and read everything on here and I've been doing audio/electric in cars for a while now, this is what i've come to know as of yet the cs 130D is not exactly the cream of the crop...I had a factory one in a car with 140k I put in a small system, 2 audiobahn aluminum 12's and a 800watt audiobahn amp, with 1 farad cap, and i fried it, next step was a 220AMP...well this one failed inside a monthe with 3 audioban alum12q's and a 1000watt rockford amp, 1000watt generic amp and 3 farads to back it up, as well as 0/0gauge main wire and 4gauge feeds to the electrics, topped with 2 seperate 0/0 gauge grounds-this was just under the hood....the rest was feed through a 0/0 and 0/1 gauges each component having it's own ground, and i'm not so sure you can get above 105amp factory...that i don't know, i went straight to aftermarket, but my lights still would dim.....now I have a factory power rebuild on my oem alt. but I am running just the 1000w amp rockford 2 farads and 2 rockford p3's and its definately not near enough, but my second rebuild on the 220A should be here in about 2 weeks, also a capcell is goign to be added...maybe that will help out. either way the design is flawed and unless you don't wanna go big with your system its gong to be a never ending process. the cs144 is pretty tough as of yet in my mind, I have 2 LTZ's both have had systems in and out ranging from my smallest 500watt kenwood and 2 RF10's, upto 2 JL 12 W6's and a 1000.1 JL AMP no wiring upgrades, a 0/1 gauge feed to a 600amp capcell then to amp, and a 0/0 ground, both have been replaced one time, just with a palladium rebuit one from advance, wait I take it back my 98 is currently running on it's third. i'm going to try 3 RF p3 12's on a 1000.1 RF amp and a 2 farad cap and see what happens as for the two being interchangeable is a question i cannot answer thats my experience with my own personal vechicles where I know what happened....i.e. not a customers.. the wiring upgrade is definately where you will see the most drastic improvement, and I know this sounds obvious, but MAKE SURE all your connections are good, CLEAN (espicallly the grounds), and solid the charging wire the line to the starter the ground off the batt ....now you can and probably should add in these (I did) line to fuse blocks ground off the engine block or head depending on the car..both FUSES/CIRCUIT BREAKERS ON ALL MAJOR HOTS..i.e. the charging wire hope this helps someone Quote Link to comment Share on other sites More sharing options...
Garrett Powered Posted July 23, 2011 Report Share Posted July 23, 2011 the lumina LTZ comes with a 140 amp cs144 and it should be a perfect match even for the GTP's, i'm using it for my top swap are you sure? I am still trying to find out more info on this is why. stock cs144? I would like to see a pic of this. wait, no, you have a 3800 with a cs144? never heard of that. Quote Link to comment Share on other sites More sharing options...
RobertISaar Posted July 23, 2011 Report Share Posted July 23, 2011 check out rockauto: 98 lumi LTZ w/3800: the police packaged cars got a 140 amp piece. no idea what it is though. Jim_rockford_007 1 Quote Link to comment Share on other sites More sharing options...
pshojo Posted August 30, 2016 Report Share Posted August 30, 2016 Police package on Impala too? Quote Link to comment Share on other sites More sharing options...
Nas Escobar Posted August 30, 2016 Report Share Posted August 30, 2016 Police package on Impala too? I would assume so. I know the H bodies had bigger amped alternators on their 3800s. I forget if they were 120 or 140 amp though. I know the Eldorado had 140 though. Quote Link to comment Share on other sites More sharing options...
l67ss Posted August 31, 2016 Report Share Posted August 31, 2016 Police impalas got 125 amp alts. The 05 police impala alt on my 97 Monte has done me well. Plus you use the better 99+ alt bracket Quote Link to comment Share on other sites More sharing options...
Jim_rockford_007 Posted December 30, 2019 Report Share Posted December 30, 2019 Get an alt for a 1999 lumina 9c3 they have the CS144 140 amp for the 3.8 Quote Link to comment Share on other sites More sharing options...
