wickedbuick Posted June 14, 2010 Report Share Posted June 14, 2010 How much did the box of fittings cost you? And were you able to fit the T's over the pressure regulator and the supercharger attachment as well? It cost me about 8 bucks for the fittings and the hose was about $2. I think I got about 2ft to be sure I'd have enough. There is a smaller box on their site for $5 and a pic of them too. Basically you fit a short piece of line over the end of the lower part of the T and push it onto the lower intake nipple and then more hose to go around to the FPR and the boost bypass. You can get line small enough to push the stock line from the MAP sensor directly into the rubber line coming from the other side of the lower intake T. http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp;jsessionid=5325605C1738E0207CA640A7B56A1273.diyprod1-b2c2?counter=15&categoryDisplayName=Fastener%2C+Screw+and+Hardware&fromString=search&itemIdentifier=426013_0_0_&productId=426013&sortType=&parentId=1313-10&filterByKeyWord=Vacuum+connector&navValue=100798&categoryNValue=101313&fromWhere=&itemId=798-10&displayName=Vacuum+Connector+and+Tubing&store=1265 Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted June 14, 2010 Report Share Posted June 14, 2010 It cost me about 8 bucks for the fittings and the hose was about $2. I think I got about 2ft to be sure I'd have enough. There is a smaller box on their site for $5 and a pic of them too. Basically you fit a short piece of line over the end of the lower part of the T and push it onto the lower intake nipple and then more hose to go around to the FPR and the boost bypass. You can get line small enough to push the stock line from the MAP sensor directly into the rubber line coming from the other side of the lower intake T. http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp;jsessionid=5325605C1738E0207CA640A7B56A1273.diyprod1-b2c2?counter=15&categoryDisplayName=Fastener%2C+Screw+and+Hardware&fromString=search&itemIdentifier=426013_0_0_&productId=426013&sortType=&parentId=1313-10&filterByKeyWord=Vacuum+connector&navValue=100798&categoryNValue=101313&fromWhere=&itemId=798-10&displayName=Vacuum+Connector+and+Tubing&store=1265 I can take pics of mine if you need me to. I should be home in about 2-3 hrs. Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted June 14, 2010 Report Share Posted June 14, 2010 you have that backwards.... no vacuum at the FPR will make too much pressure... On this Robert is right. It will run at static pressure without a vacuum line. You'll see the change in pressure if you hook up a fuel pressure gauge and pull the line off at idle. It still shouldn't affect WOT i don't believe.... Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 14, 2010 Author Report Share Posted June 14, 2010 I can take pics of mine if you need me to. I should be home in about 2-3 hrs. Yeah pics would be great, that was my only major concern about getting universal but I'll just go ahead and pick up those parts now. Quote Link to comment Share on other sites More sharing options...
RobertISaar Posted June 14, 2010 Report Share Posted June 14, 2010 On this Robert is right. It will run at static pressure without a vacuum line. You'll see the change in pressure if you hook up a fuel pressure gauge and pull the line off at idle. It still shouldn't affect WOT i don't believe.... correct, if there is a check valve to prevent boost from reaching the diaphragm. otherwise, fuel pressure will rise with boost pressure. Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 14, 2010 Author Report Share Posted June 14, 2010 Yeah WOT it's typically fine, it's lower Rpms in city when I started getting the problems. Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 14, 2010 Author Report Share Posted June 14, 2010 This is what I've got going on so far, I still need to go back and get some end plugs, another L joint (the one on there is apparently cracked as well, and 2 more 5/8 T's. Im using the 1/8's on there now for the extra 2, only two came with the package so Im just going to go back and get 2 more 5/8's before I install it. But it seems like it'll work. Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted June 14, 2010 Report Share Posted June 14, 2010 This is what I've got going on so far, I still need to go back and get some end plugs, another L joint (the one on there is apparently cracked as well, and 2 more 5/8 T's. Im using the 1/8's on there now for the extra 2, only two came with the package so Im just going to go back and get 2 more 5/8's before I install it. But it seems like it'll work.[ATTACH=CONFIG]1103[/ATTACH] Looks like you've got it! Let me know if that doesn't work for you. I don't think you'll have any problems though. Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 14, 2010 Author Report Share Posted June 14, 2010 (edited) This T is giving me a problem, the old T on the right got overstretched and broke off from them trying to put it on the nipple, and my little 5/32 tubing wont go over the nipple without damaging it. I'd get a larger tubing for that specific nipple but then it wont fit over the universal T Small piece of 5/32, some sort of adapter and some 1/4? Edited June 14, 2010 by Mach Jace Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 14, 2010 Author Report Share Posted June 14, 2010 Oh wow, nevermind, I've got an adapter in the kit I bought that'll fit just perfectly. Zing! Quote Link to comment Share on other sites More sharing options...
tornado_735 Posted June 15, 2010 Report Share Posted June 15, 2010 "yeah, see if the that there crank sensor doesn't see the motor spinin' it won't angage the starer right, HERPDERP!" That is the most absurd thing I have ever read in my entire life. Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted June 15, 2010 Report Share Posted June 15, 2010 Oh wow, nevermind, I've got an adapter in the kit I bought that'll fit just perfectly. Zing! Looks like everything is coming together perfectly. Good job! Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 15, 2010 Author Report Share Posted June 15, 2010 EPIC FIX! I legitimately scared the living shit out of myself when I accidentally floored the gas in park instead of the brake, I think I woke the whole neighborhood. The car freaking roars, and its nice to finally feel its full potential without that vacuum leak and the mis. Thanks for all the help guys. One more small thing, I'm "pretty" sure there's supposed to be a bolt here, judging from the oil that's dripping out of this hole... Either that, or its how the magical flux capacitor works in order to fuel that crank shifter sensor beam...laser...thing. Anyone know what size it is? Sorry if the picture is a bit dark. Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted June 15, 2010 Report Share Posted June 15, 2010 Can you circle that in Ms paint? Sent from my T-Mobile myTouch 3G using Tapatalk Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 15, 2010 Author Report Share Posted June 15, 2010 Sorry Andrei, I can't circle it, best I can do is square it. Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted June 15, 2010 Report Share Posted June 15, 2010 Does anyone here have an L67 that can look at that stupid bolt hole that's directly under the LIM to figure out what in the world is supposed to plug it up? Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 15, 2010 Author Report Share Posted June 15, 2010 Photo enhanced for your viewing pleasure: Quote Link to comment Share on other sites More sharing options...
Mach Jace Posted June 15, 2010 Author Report Share Posted June 15, 2010 Ignore the guitar in that post...apparently deleting a thumbnail is harder than it looks Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted June 15, 2010 Report Share Posted June 15, 2010 Does anyone here have an L67 that can look at that stupid bolt hole that's directly under the LIM to figure out what in the world is supposed to plug it up? I don't recall that threaded whole. I'll look tonight. I'll be home from work by 7:30 hopefully. Quote Link to comment Share on other sites More sharing options...
Night Fury Posted June 16, 2010 Report Share Posted June 16, 2010 Nice random guitar Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted June 16, 2010 Report Share Posted June 16, 2010 I took some pics last night but I forgot my damn memory card at home lol Yes there is a torx head bolt in that hole. I have not tore one of these engines down completely so I can't say what its for. I can't see it being a major issue if you've been driving like that and you still have 90% of your oil at all times. I didn't remove mine so I can't tell you the thread pitch, diameter, or length to get a replacement. It's cheap enough to buy a few diferent ones from lowes and just return the ones that don't fit though. I'll post the pics up tonight. Quote Link to comment Share on other sites More sharing options...
Addicted to eaton Posted June 16, 2010 Report Share Posted June 16, 2010 LOL, ass beat me to it! there ya go, Not a major issue But it plugs up a hole going on to the lifter valley. Quote Link to comment Share on other sites More sharing options...
xtremerevolution Posted June 16, 2010 Report Share Posted June 16, 2010 LOL, ass beat me to it! there ya go, Not a major issue But it plugs up a hole going on to the lifter valley. Any idea what purpose it serves? Quote Link to comment Share on other sites More sharing options...
Addicted to eaton Posted June 16, 2010 Report Share Posted June 16, 2010 I pulles it out, its 3/4's and inch long, It keep stuff from getting in the oil of our cars. My guess, maybe the its a place for the coil bracket to bolt to on other 3800 powered cars (non w-body) Quote Link to comment Share on other sites More sharing options...
wickedbuick Posted June 16, 2010 Report Share Posted June 16, 2010 (edited) Any idea what purpose it serves? Not sure exactly. I put my cam in and had the whole top end off and never paid attention to that bolt lol Maybe some secret port that dealers use for diagnostics lol Question should be is it on the L36 and if so maybe the hole is for brackets or something on an Fbody application....... EDIT: Duh it would be on the L36. lol I meant is it on all series 2 3800's or something in its place haha Edited June 16, 2010 by wickedbuick Quote Link to comment Share on other sites More sharing options...
