hell_raiser Posted May 22, 2007 Report Share Posted May 22, 2007 hey is there away of putting the mini quads from a coup on on 4 door like the whole front end ? maby make the arse end look the same by cuttin it off a 2 door and welding the coup back on the sedan? i want the look of a 2 door but the use of 4 doors lol the car is lowered and has all coup suspention breaks and stuff it has a 3.4 doch swap and 5 spoke rims it looks good its dark green Quote Link to comment Share on other sites More sharing options...
mediabandit Posted May 22, 2007 Report Share Posted May 22, 2007 any pics? Quote Link to comment Share on other sites More sharing options...
19Cutlass94 Posted May 22, 2007 Report Share Posted May 22, 2007 you have to swap the whole front end on. Youll also have to swap the whole ass end on as well. Although I dont think the ass end will work because I think the quarters are different between the coupes and the sedans, especially around the taillight. And yes the coupes and sedans will have the same suspension parts, theres nothing special about that. BTW, spelling owns you. Quote Link to comment Share on other sites More sharing options...
Dirty Rockstar Posted May 22, 2007 Report Share Posted May 22, 2007 You can go two ways with this. Way one: Get the coupe mini quads, hood, bumper, and fenders. Grab the associated wiring pigtails to be safe too becasue I think the foglights are different bulbs. Then if you're up to it, cut your sedan bumper and coupe bumpers at the top seam. Then merge the sedan bottom to the coupe top. Fiberglass, bondo, sand, prime (x100000), paint, and clear. This would be the easiest, plus you can retain all your stock body cladding. Way two: DO the same as above. But also get yourself two sets of side cladding from the coupe. It will be easier to cut the long pieces shorter than to make the short ones longer. And would look cleaner. As for the rear bumper, do the same as I described for the front bumper in Way One above. This will allow you to retain the stock tail lamps. I was looking into swapping on coupe tails. That gets into expensive metal work I wasn't going to even TRY to mess with. I had intended to try this swap, but I plan to buy a convertible so I 'drydocked' the idea. I might get a sedan again and try something similar, or make the Aerotech III concept a reality. Good luck. EDIT: Forgot to tell you some important info. You WILL need the header panel and turn signal markers for the front. The header panel, just FYI, is where the lights and all that jazz mount to. Quote Link to comment Share on other sites More sharing options...
hell_raiser Posted May 22, 2007 Author Report Share Posted May 22, 2007 pics as of now no spelling your fing rite lol thanks man dose any one have a mini quad pic on a sedan? Quote Link to comment Share on other sites More sharing options...
Dirty Rockstar Posted May 22, 2007 Report Share Posted May 22, 2007 I'm sure you would be the first on this site to do this to a Cutlass. Quote Link to comment Share on other sites More sharing options...
FordBoy Posted May 22, 2007 Report Share Posted May 22, 2007 well now i aint the only bad spelled person on here Quote Link to comment Share on other sites More sharing options...
blkinternational Posted May 22, 2007 Report Share Posted May 22, 2007 what did you lower the rear with Quote Link to comment Share on other sites More sharing options...
GnatGoSplat Posted May 24, 2007 Report Share Posted May 24, 2007 The door curvature wouldn't match up. The coupes have a little bit of a "shoulder" that sedans don't have. You'd need custom-made door skins. I suppose you could make some out of a bunch of 2dr skins. I'm not sure a 4dr with coupe parts would still look as good as a real coupe because the roofline is sleeker on a real coupe. Quote Link to comment Share on other sites More sharing options...
IRONDOG442 Posted May 24, 2007 Report Share Posted May 24, 2007 well now i aint the only bad spelled person on here Clint, it's not too late you can still get your bid!!! http://www.w-body.com/forum/index.php/topic,60682.0.html Quote Link to comment Share on other sites More sharing options...
Pontiac6KSTEAWD Posted May 24, 2007 Report Share Posted May 24, 2007 Hooked on phonics didnt work for you!! (jest messin) Quote Link to comment Share on other sites More sharing options...
