kbviper Posted March 8, 2007 Report Share Posted March 8, 2007 Hi, I'm brand new to this forum. I'm wondering if anyone would know a source for the following parts: 1. The rubber windshield molding that pushes into the metal frame on the top and two sides. I've got one vert missing it completely, another with it messed up a bit from when the w/s was replaced. 2. The two plastic cups that the pins go into on the header. Need lots of other parts for one including trunk side lining pieces, and could use a teal hood and p/f fender. Also, has anyone replaced their %@$% door handles. They are good on two of the cars I have, and messed up on the other, although they still work. I bbought two good used handles, keyed the same, c/w key. I have the 1994 shop manual (car is a 94) but I was just wondering how anybody who has swapped the handles found how it was to do. Quote Link to comment Share on other sites More sharing options...
Psych0matt Posted March 8, 2007 Report Share Posted March 8, 2007 as for the #1 and #2, good luck, I know a bunch of us are looking for them best bet is to hit up as many junkyards as possible. Door handles aren't that hard, however I have never done it (or had to) Quote Link to comment Share on other sites More sharing options...
Crazy K Posted March 8, 2007 Report Share Posted March 8, 2007 1 and 2 good luck there too. door handles can be replaced easy enough. got a source of replacements? Quote Link to comment Share on other sites More sharing options...
DavidHowell3633 Posted April 24, 2007 Report Share Posted April 24, 2007 The door handle is pretty easily replaced. But, the new one will break if your door is rubbing on the sill. These convertibles get a bit swayback over time. You can shim the lower door hinge and fix it for good. I bought two driver door handles in 6 months before I learned this one. David Quote Link to comment Share on other sites More sharing options...
