88GPSE Posted April 3, 2006 Report Share Posted April 3, 2006 Kind of a double question. I was doing tuning on my dad's pick--up and I got the itch to do some work on both my J-body Cavalier hybrid motor(3100 heads/intake on 3.1L block) project in my Fiero and my girlfriend's 88GPSE with SD cnversion (memcal from 89 Olds with 2.8 SD) Which ALDL data stream definitions do I need? both are 730/727 P4 ECM's. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
DaveFromColorado Posted April 3, 2006 Report Share Posted April 3, 2006 not sure which def's to use ... but I do gotta ask ... why go to the SD setup, I'd imagine you'd have a lot more room for accurate tuning with the MAF setup, then with the SD - plus, if you wanted to force some air down into it, it'd be much easier to tune with the MAF then with a 2 or 3 bar MAP sensor. --Dave. Quote Link to comment Share on other sites More sharing options...
88GPSE Posted April 3, 2006 Author Report Share Posted April 3, 2006 someone already did it before she got the car. I found the same 4 letters on an olds cutlass ecm iin a yard last weekend Quote Link to comment Share on other sites More sharing options...
