  1. Black92GS
    Black92GS
      146
  2. Psych0matt
      11,084
  4. SuperBuick
    SuperBuick
      589
Showing content with the highest reputation on 05/14/2025 in all areas
    92 (88-94?) sunroof relay
    The sunroof switch is a rocker switch, depending on which side of the switch one presses (front side or rear side) the switch closes the circuit to either the forward relay or the back relay. The direction of sunroof movement remains in play until the end of stroke as long as one has the switch pressed. If the sunroof glass has been opened & one presses the front side of the rocker switch the glass moves forward to the closed position, one releases the switch at the point the glass is closed to keep the glass closed, if one continues to hold down the front side of the switch the glass will open up to the vent position. The same control function takes place when retracting the glass to full open, when the glass goes to full open the glass stops moving, the load comes up on the motor circuit, no voltage is flowing, so both relays go open, this same action applies when the vent goes to fully open.
  2. Psych0matt
    It looks like the end plug is wired the same (looks like power?) but has a different connector, and the second to last one as well and has the same connector, so the main difference is on the original the first plug (that goes to the stop switch) has three wires, but on the new it only has 2, with the third wire going to the second plug instead; both of those having different connectors as well. I’d bet this would function the same if repinned/spliced to the correct connectors. Some are different sizes so I don’t think I can just reuse the end connectors without splicing
  3. Psych0matt
    Pics since they wouldn’t upload here https://imgur.com/a/0TaF7Mj Link from Nate for diagram https://charm.li/Pontiac/1992/Grand Prix V6-204 3.4L DOHC/Repair and Diagnosis/Diagrams/Electrical Diagrams/Sunroof %2F Moonroof/
