  2. Nas Escobar
    Nas Escobar
      3,714
      9,318
  4. Amanita
      367
Showing content with the highest reputation on 04/12/2020 in all areas
    Engine Support tool vs LQ1
    Thats the supervisor and he reminds me constantly, my sister couldnt keep him years ago and just sort of showed up with him, 12-13 years later I`m now his human. A few things going on here, most pending was the rear subframe bushings were soggy and the front couldnt be aligned according to the Goodyear tech and my floor jack slid off the subframe on to the oil pan and I worried the oil pump might be damaged. Also a P/S fluid leak at the sensor or line, seepage from the pan gasket, the metal coolant line running down the passenger side I wanted to paint and put a protective sleeve over, fix an ABS wire, all new solid Eng/Trans mounts, new C-arms and also went looking for a lost socket. Oil pump was absolutely fine, a good 4 inches exists between the base of the pan to the pickup tube, I just banged the dent out with a hammer and block of wood, little bit of sandpaper and black paint, good as new. Not one little bit of sludge or metal when I wiped it out either. I still want to spray the subframe down with brake cleaner before I paint it, Lowes has something just a step down from POR15 I`ll use, there was a bit of old O-ring stuck down in the R&P outlet threads which I think was causing the leak but I`ll change out the o-ring on the sensor just to be sure. Waiting on parts so I'm doing some hardscaping in the yard til then.
