  1. NCTyphoonKid
    NCTyphoonKid
      481
  2. Breakdown
  3. Galaxie500XL
      9,326
Showing content with the highest reputation on 11/04/2019 in all areas
  1. pbender
    Restoration project...
    So it has been a long time since I posted here.... and Shawn ( @GnatGoSplat) probably thinks I’m crazy for starting this project, but... Yesterday I rescued my 1993 Cutlass Supreme Convertible from what used to be a lumber yard in Byhalia,OH where it had sat for almost exactly 11 years ( it was parked there in October, 2008 ). I am in a bit of damage/deterioration determination mode at the moment. When she was parked, the motor was partially disassembled, so obviously there is some work to be done under the hood. The drivers side window was broken at some point, so that will need to be replaced, and at this point I don’t know if any of the interior parts have damage that needs to be repaired or replaced due to the layer of dirt and dust and other debris I still need to clean out of the car. Getting her up on the trailer ( and back down again ) was fun... the passenger side rear wheel isn’t spinning. Surprisingly, all 4 tires took air, though the drivers side front would only hold it about an hour. Passenger side front was better. It took 12 hours before it went flat.... Next task is to look through the pile of parts ( and repair manuals ) I put in the trunk all those years ago... I need it clear so I can see if the top still works....
    Door panel removal.
    All of the door clips look like these...... There is a large philips headed screw under the pull handle that takes most of the load when one pulls on the door, the bottom seatbelt retractor cover has a pair of screws that are under the very bottom of the trim cover. There is also another retaining screw in behind the door panel lamp at the rear of the trim panel. One has to carefully pry out the lamp housing to get at the retaining screw.
  3. Human
    Door panel removal.
    If the GP is anything like my '95 Cutlass Supreme, it's pretty easy to take off. No special tools needed, just screwdrivers. You'll need a flat blade screwdriver to pry off the little cups behind the door handles and Phillips screwdrivers for several more screws at various other spots. The screw that's often overlooked on the Cutlass Supreme is in the bottom of the door pocket. Someone overlooked it on mine and tore it up on the driver's side. I need to find a new one but the only one I've ever seen at a boneyard was similarly damaged. Also, be prepared and have a supply of the nylon fasteners that hold the panel in place because you'll definitely need to replace at least a few of them. Fortunately, they're pretty cheap.
    So excited to see another one getting saved! I just love the red color and like Manic said, looks really solid. Congrats and I think it's so cool bringing back W-Bodies from the dead. I saved two W's from definitely getting scrapped and I found them in the same situation as you. My 91 International sat in the original owner's back yard since 09. I saved it in Dec of 2015. I bought my 93 STE last year from the original owner's son. It's been sitting in his front yard in the CA desert since 2010. I saved it this past June. Nothing beats seeing W's on Uhaul trailers, LOL! I'm using way too many exclamation points but so excited to see another CS!
