Digi UB3 adapter
This thread is 15 years old.
Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special. - Earlier
charm.li free forever
89 olds swaybar
