94 olds vert reacted to a post in a topic: convertible carpeting
Bake82 reacted to a post in a topic: It's begun! - 2nd Gen W-Body 3800 5-speed F23 Swap
Yeah, one could do that, or......pick up a set of these - Last week
Axel736 joined the community
I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. I’ve tried about 8 different ones and every one leaks . Any help would be much appreciated -
Brake Line Size
Yes! that is the tool I was able to use as well. But I couldn't seem to fit the spanner nut down the strut tower hole because I didn't have any clearance to fit the nut socket in there. - Earlier
