94 olds vert reacted to a post in a topic: 89 Oldsmobile Cutlass Supreme door armrests sticky and gooey
Yep, I've also read it's not reversible, which is pretty annoying to have to clean it with alcohol all the time. It's been out of the sun for the last 5-years, but the damage is already done. Also gets pretty hot in the garage and I'm sure that doesn't help. Only permanent-ish solution I could really think of is to have it wrapped in color-matched leather. Might look nice if professionally done. Only thing is if leather needs to be glued down, it wouldn't stick for long if the vinyl underneath keeps sweating. Maybe it would need to have the vinyl stripped off, then built up and sculpted with some other material to the right shape so that part can be leather-wrapped. Sounds like very high cost. Other parts of the car would need attention before I go to that extent to fix it though. -
GnatGoSplat reacted to a post in a topic: 89 Oldsmobile Cutlass Supreme door armrests sticky and gooey
94 olds vert replied to GnatGoSplat's topic in Appearance/Car Care
This is something that I remember hearing about years ago about when modern day cars would age. The plastics would decay and the first stage is when they get sticky. Then over time that stops and the plastics dry out and get hard and start to crack. I don't think it's possible to reverse this process once it get started. I know it's a big issue on foreign cars that are around 20 years old. They always seem to get the sticky buttons. It is just going to keep happening. The best thing would be to clean, protect and keep it out of the sun to reduce the decay rate. Unfortunately these cars don't have a lot of aftermarket support, so getting new interior pieces isn't really an option. Buying a used one is likely going to have the same issue. Pretty impressive the car went 30 years without having that problem. Lasted much longer than most. -
GnatGoSplat started following 92 Oldsmobile cutlass supreme A/C evaporator replacement and 89 Oldsmobile Cutlass Supreme door armrests sticky and gooey
GnatGoSplat posted a topic in Appearance/Car Care
It's a bit of a bummer, my 89 Cutlass door armrests are very gooey and sticky due to sweating plasticizer. It's been going on the past few years. I've read this is how vinyl decomposes, and it won't stop until the vinyl becomes hard, brittle, and cracks. I've been cleaning it off with isopropyl alcohol in the meantime, but it's just temporary. Going to try cleaning it again, then putting 303 Aerospace Protectant on it. Anyone else have this problem and found a solution that works? -
This is all I could really find for free. https://charm.li/Oldsmobile/1992/Cutlass Supreme FWD V6-189 3.1L/Repair and Diagnosis/Heating and Air Conditioning/Evaporator Core/Service and Repair/ Although I 100% agree that you should get the genuine GM service manual. Well worth the $7.50+shipping. https://www.ebay.com/itm/235434976664 -
55trucker reacted to a post in a topic: Mono spring delete or suggestions
Wanted to update this topic. The lubricate spray appears to have solved the issue and is holding up the conditions it is being exposed to. Thanks to all who have helped! -
How to lower a W-Body ( Gen 1, Gen 1.5 )
SuperBuick replied to 19Cutlass94's topic in Brakes/Suspension/Steering/Wheels/Tires
Does anyone have a picture of where they cut the front spring, or a picture of the spring after cutting? - Last week
Yeah, one could do that, or......pick up a set of these -
Axel736 joined the community
I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. I’ve tried about 8 different ones and every one leaks . Any help would be much appreciated -
Brake Line Size
