  2. What is the GM part number for the O-ring? Find out, and cross it to something in the aftermarket if the GM part is discontinued.
  3. Today
  4. The Genuine GM service manual set for your vehicle is your friend. First Guess: If you can get in there from the HVAC blower-motor area with a vacuum, and perhaps compressed-air on a long, thin nozzle, you don't have to take the evaporator OUT. Then the A/C system doesn't have to be discharged, desiccant pouch replaced, (new accumulator) system evacuated, and re-charged. IF (big IF) the system is still leak-free, you aren't disturbing any of the seals. OTOH, it's a pain in the tuckus to REALLY clean an evaporator. But it's probably even worse to replace one. Good luck. If you do have to open the refrigerant system, be sure to replace the desiccant, and be sure to replace EVERY O-RING IN THE SYSTEM. And have a careful look at the condenser for leaks and folded-over air fins. Might be a good idea to just upgrade the condenser while the system is apart. Remove and examine the orifice tube--any debris, and you need a compressor, too. Flush every part you intend to re-use (except the compressor) and use the correct oil for the refrigerant you're using--in '92, that'd be R12 as OEM. So again, "good luck".
  5. Hello if this has been posted already it would be greatly appreciate if someone can share a link to how to replace the ac evaporator in my 92 . It’s so packed full of junk it hardly blows any air and blew out the seal at the bottom so clearly I need to remove and clean it out. &nbsp
  6. Yesterday
  7. I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. I’ve tried about 8 different ones and every one leaks . Any help would be much appreciated
  8. Last week
  9. rich_e777
    convertible carpeting
  10. I will remember not to use the impact on the new ones and use the socket. I will have to torque to specs anyhow the nut on top. I try to use the Torx and socket on the old struts but it was so dirty I wouldn’t come loose and stripped the thread. So I used an impact to remove the nut.
  11. Mike1998Lumina
    Brake Line Size
  12. The #50 torx tip is needed to stop the piston shaft from rotating in the shock housing while undoing & tightening up the the retaining nut. As I stated earlier some aftermarket shocks no longer make use of a torx design for the socket interface at the top end of the piston shaft. Spinning the piston shaft with an impact gun is not desirable. Doing so with the outgoing shock is alright but no so with the new shock.
  13. Then you are looking for an OTC 7568A kit. Where are you going to find just the tool you need?
  14. So seeing the photos you posted that’s all I need those tools? I wouldn’t need the whole kit.
  15. It would be cheaper I think just to get the tools I need. I don’t really need the Torx socket or that other socket it goes with it because I can remove the nut with an impact and I have that long strut spreader cylinder tool.
  16. The strut kit i have says OEM # 27034. This is the same kit that Autozone used to rent. I see ebay has the same kit listed as T&E Tools AT185.
  17. Which kit is this? Any brand names I can buy with everything I need? One kit i bought was kent moore that was originally used by GM Dealers when these cars were new. The tool service kit was missing tools so I had to buy some tools extra that weren't in the kit. When I didn't have luck removing the strut cartridges I sent it back.
  18. Which kit was that in and is that the nut from the cartridge that long tool fits over?
  19. I have this exact tool I bought off ebay with the nuts that tighten this down. Mine didn't fit because it was too tight. But you need to move the strut a little to the sides so this can fit down the strut tower ?
  20. Yes! that is the tool I was able to use as well. But I couldn't seem to fit the spanner nut down the strut tower hole because I didn't have any clearance to fit the nut socket in there.
  21. primergray
    Sitting 1995 Regal GS
  22. architect
    TRW Keyless Entry module
  23. GnatGoSplat
  24. architect
  25. architect
  26. Earlier
  27. GnatGoSplat
  28. architect
  29. architect
  30. GnatGoSplat
