GnatGoSplat started following 92 Oldsmobile cutlass supreme A/C evaporator replacement
This is all I could really find for free. https://charm.li/Oldsmobile/1992/Cutlass Supreme FWD V6-189 3.1L/Repair and Diagnosis/Heating and Air Conditioning/Evaporator Core/Service and Repair/ Although I 100% agree that you should get the genuine GM service manual. Well worth the $7.50+shipping. https://www.ebay.com/itm/235434976664 - Today
55trucker reacted to a post in a topic: Mono spring delete or suggestions
Wanted to update this topic. The lubricate spray appears to have solved the issue and is holding up the conditions it is being exposed to. Thanks to all who have helped! -
How to lower a W-Body ( Gen 1, Gen 1.5 )
SuperBuick replied to 19Cutlass94's topic in Brakes/Suspension/Steering/Wheels/Tires
Does anyone have a picture of where they cut the front spring, or a picture of the spring after cutting? - Last week
Yeah, one could do that, or......pick up a set of these -
Axel736 joined the community
I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. I’ve tried about 8 different ones and every one leaks . Any help would be much appreciated -
I will remember not to use the impact on the new ones and use the socket. I will have to torque to specs anyhow the nut on top. I try to use the Torx and socket on the old struts but it was so dirty I wouldn’t come loose and stripped the thread. So I used an impact to remove the nut. - Earlier
Brake Line Size
