  1. Last week
  2. 55trucker
    4T65E Range Selector Bracket
  3. phewop118
  4. 94 olds vert
    Digi UB3 adapter
    This thread is 15 years old.
  5. rich_e777
    Digi UB3 adapter
  6. The LQ1 timing stuff looks intimidating until it's laid out step by step. That video saves a lot of random forum digging.
  7. hazelspindle3
    New member with 98 lumina
  8. hazelspindle3
  9. calmspindle6
    New to this place. Hello.
  10. That video is one of those rabbit holes where you start with a tensioner and end up learning the whole LQ1 timing setup. Pretty handy to have around.
  11. covefinch9
  12. A reman label really muddies the water, so the broadcast code is the one piece that settles it. A logger that connects with the wrong stream can look believable right up until it sends you chasing nonsense.
  13. Those convertible-specific seals and interior bits can be a real scavenger hunt, but an 80k car that's been garaged is a solid starting point. Getting him one more ride in it would be pretty special.
  14. mossyelk
  15. briskshovel88
    Rough idle/ volt drop
  16. pwmin
  17. Kdog
    charm.li free forever
  18. Earlier
  19. Jscott
  20. do i leave it white ,or do i use, the red line ?
  21. fern_anchor
  22. willowhammer2
    89 olds swaybar
  23. bluecalais79
    A/C Repair - LQ-1
  24. leafyrook67
  25. brightbuck95
    A/C Repair - LQ-1
  26. bluecalais79
  27. bluecalais79
    A/C Repair - LQ-1
