TBH I thinks its going to take exactly that, but not before this and then might as well replace that. But then oh if we`re going this far might as well go all in or it wasn't worth putting in at all because it just isn't the right way. Le Damnit`e Its under a cover for the most part while I sort out some non-brake related issues, highly recommend Seal Skin for covers.
I'm finding I hate driving my 'vert at night
94 olds vert replied to Human's topic in Cutlass Supreme Convertible
Back during the recession in '08 these cars littered the junkyard. I used to stack up on parts. -
89 olds swaybar
nimbletern88 replied to sadolboy48's topic in Brakes/Suspension/Steering/Wheels/Tires
Could be worth checking old Regal and Grand Prix listings too, people often part those out without tagging the suspension bits. That early loop-end setup really narrows the hunt. -
Cnuts24 started following SuperBuick
Human replied to Human's topic in Cutlass Supreme Convertible
I can agree about the headlights. Their performance is about average for the mid-'90s. I looked one time for a replacement headlight switch, but couldn't find one with the fog light switch, so I doused the one on my car with contact cleaner. It might have helped a little. -
I remember my 94 CS, and the dash lights were always bright.The headlights not so much. Replacing the headlight switch did fix some intermittent dimming issues -
Thanks for the video. That is exactly what mine desperately needs! It's great to get an idea of what it might look like with the LEDs in place. I realize your dash is different from mine, but how much trouble was it to swap out the bulbs for LEDs? Was anything else needed or was it just a direct swap? I've had the dash bezel off on mine several times, swapping radios, but I've never taken the gauge cluster out. I'm really looking forward to being able to see my instruments at night. -
jmjp5055 started following I'm finding I hate driving my 'vert at night
I changed most of the dash , interior and exterior bulbs on my ‘94 cutlass convertible to led , I purchased most of what l needed on ebay. There’s a video showing what it looks like at night. IMG_3530.mov -
I just ordered some LEDs to replace the OEM bulbs ($8.89) for a box of 10. They're supposed to be a direct replacement for the bulbs and brighter to boot. We'll see. There were several color options. I briefly thought red might be fun, but I decided white would be the brightest. -
It does not appear that any bulbs are burned out because the lighting is uniform, albeit ridiculously dim, across the panel. I can imagine that dust might be a possible culprit. I've just got to figure out how to get in there to clean off the bulbs. I have also noticed the other evening is the panel lights were fairly bright when I first turned the lights on, but then quickly became progressively dimmer. I can still see the needles, just not what they're pointing to. It's also possible that could be an optical illusion caused by changing levels of ambient illumination (e.g., street lights, headlights from other vehicles, etc.). If I end up replacing the bulbs, I would want to investigate options for brighter ones. Meanwhile, I'll continue to endeavor to minimize nighttime driving as much as possible. -
jadeshearwater960 joined the community -
White93z34 replied to Human's topic in Cutlass Supreme Convertible
Well, a 95 is now 31 years old... a lot has changed since then. Possible that the bulbs are dusty/dim you could try replacing the illumination lamps in the cluster - perhaps one or more is burn out. Or perhaps we're just spoiled by new cars and thats just how it is... -
nimbletern88 joined the community -
My car is currently at the mechanic after the technician repaired my main engine harness, I guess when I put my engine back together I smashed the harness behind the AC compressor bracket. Mechanic ended up bypassing To a known good 5 Volt reference after he got the same numbers that I got when I back probed my MAP, IAC and TPS. He then informed me that I had board damage on my ECM and that a 12 Volt being fed to my ECM couldn't have been good. I ended up purchasing a spare ECM. I'm preparing to head there and connect TunerPro RT V6 to my 1990 Oldsmobile Cutlass Supreme 3.1L LH0 V6, 4T60 automatic, using a GM 12-pin FTDI ALDL cable. The vehicle originally had a 16198260 ECM, and I purchased a replacement 1227727 ECM. The replacement arrived with an ARZW MEM-CAL. I'm still confirming whether my original MEM-CAL was transferred. My engine has the three-solenoid digital EGR valve. I currently have A109.adx loaded, converted from A109.ads, and corrected the Transmit Stream Reply body size from 66 to 67. I'd appreciate clarification on four questions: Is A109 the correct 8192-baud ALDL data-stream definition for the 1990 W-body LH0 with digital EGR, or should I be using the $88 acquisition definition? Has anyone successfully used A109 with the 1990 W-body 1227727 ECM and original $88-family calibration? Are there any additional ADS-to-ADX conversion settings I need to verify in TunerPro RT V6? What's the best way to confirm that the ECM is transmitting valid packets, rather than merely establishing serial communication and displaying incorrectly decoded parameters? The engine has exhibited incorrect sensor-reference voltage, rich running, injector-control problems and unreliable starting. The mechanic has repaired damaged wiring, and I'm preparing to collect a fresh KOEO/cranking XDL recording. I'm trying to verify the acquisition setup before interpreting the live readings or considering additional ECM replacement. - Earlier
umbersparrow414 joined the community -
This thread is 15 years old.
