pwmin reacted to a post in a topic: Mono spring delete or suggestions
GnatGoSplat reacted to a post in a topic: Mono spring delete or suggestions
Wanted to update this topic. The lubricate spray appears to have solved the issue and is holding up the conditions it is being exposed to. Thanks to all who have helped! - Today
How to lower a W-Body ( Gen 1, Gen 1.5 )
SuperBuick replied to 19Cutlass94's topic in Brakes/Suspension/Steering/Wheels/Tires
Does anyone have a picture of where they cut the front spring, or a picture of the spring after cutting? - Last week
Yeah, one could do that, or......pick up a set of these -
Axel736 joined the community
I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. I’ve tried about 8 different ones and every one leaks . Any help would be much appreciated -
Brake Line Size
Then you are looking for an OTC 7568A kit. Where are you going to find just the tool you need? - Earlier
