Axel736 joined the community
I’m changing my reservoir on my 04 grand am. The o ring that is between the reservoir and the pump itself. Was bad. I cannot for the life of me figure out the size of the o ring. I’ve tried about 8 different ones and every one leaks . Any help would be much appreciated - Last week
Brake Line Size
