95LQ1VERT Posted May 21, 2018 Author Report Posted May 21, 2018 Idlers x2 are new, plus the tensioner pulley, actuator assembly, and belt. (I used Dayco brand) Now the belt was tight to put on even with the slack on the tensioner side. But yes I made sure to set the ball end of the actuator into the pulley, and I did use a wrench to slightly tighten the belt before pulling the pin. First photo is the ball, second is before actuator is engaged, third is engaged after pulling pin and rotating engine. Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
95LQ1VERT Posted May 21, 2018 Author Report Posted May 21, 2018 I am also getting code P0341 according to my Actron Scantool, says it's a cam sensor fault. It's plugged in its causing it to not run right over half throttle while driving it I assume. Cleared it and it was instantly back. Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Galaxie500XL Posted May 21, 2018 Report Posted May 21, 2018 I discovered once when I had a faulty crankshaft position sensor, the ECM incorrectly reported it as a cam sensor fault...I'd check wiring down there first, but a bad CPS is actually a possibility. You might want to pull the cam sensor, though, and make sure there's not metal shavings stuck to the sensor. Quote
Galaxie500XL Posted May 21, 2018 Report Posted May 21, 2018 Found my postings from here chronicling my first LQ1 timing belt replacement. It wasn't a good time. http://www.w-body.com/topic/44005-lq1-timing-belt-issues-finally-running/ rich_e777 1 Quote
95LQ1VERT Posted May 22, 2018 Author Report Posted May 22, 2018 May have found the culprit? The wires are all chafed and exposed on the harness. I moved them around and the SES light went away. Sent from my SAMSUNG-SM-G930A using Tapatalk Galaxie500XL 1 Quote
95LQ1VERT Posted May 24, 2018 Author Report Posted May 24, 2018 Nope. I didnt fix and the SES is back on, same code... ordered a new cam position sensor. Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
95LQ1VERT Posted May 29, 2018 Author Report Posted May 29, 2018 Still no luck with the new cam sensor, still acting like it hits the rev limiter at 4000 rpm. I may not get this car going this summer after all... Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
GabsOlds Posted May 29, 2018 Report Posted May 29, 2018 Maybe it's time to revisit the timing. Could be off by 1 tooth. Quote
95LQ1VERT Posted May 29, 2018 Author Report Posted May 29, 2018 Maybe it's time to revisit the timing. Could be off by 1 tooth.That's what I was thinking. Not looking forward to that! Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
95LQ1VERT Posted June 3, 2018 Author Report Posted June 3, 2018 Idk if this is normal but the tensioner pulley is leaking it's oil from the bearing. Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
95LQ1VERT Posted June 4, 2018 Author Report Posted June 4, 2018 Re-timed the cams twice and made sure everything was correct. Still having the issue where it seems to be hitting the redline when getting on the throttle at about 4k rpm... There are 2 codes present, P0341 (cam position sensor) and P1350 which is ignition bypass circuit. I'm leaning towards the Ignition side of things now because the ICM, coil packs, plugs and wires were all changed. I had an new never used ICM that I put on from my last Cutlass from ~5 years ago. Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Galaxie500XL Posted June 4, 2018 Report Posted June 4, 2018 You'll also hit a limit if the ECM believes that the car is in Park or Neutral... The redline limit, and error codes may be separate problems. Quote
95LQ1VERT Posted June 4, 2018 Author Report Posted June 4, 2018 You'll also hit a limit if the ECM believes that the car is in Park or Neutral... The redline limit, and error codes may be separate problems. I'll have to hook the scan tool up to it when I get home in the morning and see if it's reading the neutral safety switch right. Sent from my SAMSUNG-SM-G930A using Tapatalk Galaxie500XL 1 Quote
95LQ1VERT Posted June 6, 2018 Author Report Posted June 6, 2018 Swapped the old Ignition Control Module back on and that fixed the issues. Faulty "new" part caused the issues. Now there is no check engine light, and it pulls to redline! Sent from my SAMSUNG-SM-G930A using Tapatalk rich_e777, Galaxie500XL, MemphisMan and 1 other 4 Quote
GabsOlds Posted June 6, 2018 Report Posted June 6, 2018 Yaaaay! Glad it's all sorted out. 95LQ1VERT and MemphisMan 2 Quote
MemphisMan Posted June 7, 2018 Report Posted June 7, 2018 Swapped the old Ignition Control Module back on and that fixed the issues. Faulty "new" part caused the issues. Now there is no check engine light, and it pulls to redline! Sent from my SAMSUNG-SM-G930A using Tapatalk That's precisely why I don't throw away parts, especially electronic parts, even if I suspect they're broken. 95LQ1VERT, GabsOlds, Galaxie500XL and 1 other 4 Quote
95LQ1VERT Posted June 7, 2018 Author Report Posted June 7, 2018 That's precisely why I don't throw away parts, especially electronic parts, even if I suspect they're broken.Exactly, I've had a few new parts broken out of the box. And I knew it ran okay before all this work so I fugured I'd replace it and have it as a back up. And sure enough I needed it lol Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Tallest Posted June 7, 2018 Report Posted June 7, 2018 That is a beautiful car, I had one before changing to a newer model Quote
95LQ1VERT Posted June 8, 2018 Author Report Posted June 8, 2018 Still waiting to know how it turned out Got it running correctly, it's a progress thread so I'll update it as things get accomplished! Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
95LQ1VERT Posted June 8, 2018 Author Report Posted June 8, 2018 New dilemma, Strut cartridge tools are No longer available from parts stores to rent... [emoji30] Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
rich_e777 Posted June 8, 2018 Report Posted June 8, 2018 Yeah you can only special order buy them now at AutoZone. I`d like to get one eventually myself so if you bought one to use then wanted to sell it we might could work something out. Quote
95LQ1VERT Posted June 9, 2018 Author Report Posted June 9, 2018 Yeah you can only special order buy them now at AutoZone. I`d like to get one eventually myself so if you bought one to use then wanted to sell it we might could work something out.I just ordered one of Amazon. It's an OTC brand, so hopefully it works good. Sent from my SAMSUNG-SM-G930A using Tapatalk Quote
Imp558 Posted June 9, 2018 Report Posted June 9, 2018 I always reached through the spring with a pipe wrench. Quote
