slick Posted December 6, 2009 Report Share Posted December 6, 2009 Yeah.... and I looked for that too, but didn't see it. Maybe difference in years? Rachel is gone for the day, so I can't get anymore pictures. I didn't think that the access ports came until the 2nd gen platform, but if you think there may be an access plate, that would make life much nicer. Quote Link to comment Share on other sites More sharing options...
AL Posted December 6, 2009 Report Share Posted December 6, 2009 Youll have to check that plate out... I didnt think they came with access points but maybe someone put one in lol Quote Link to comment Share on other sites More sharing options...
nebojsa_o Posted December 6, 2009 Report Share Posted December 6, 2009 My '96 Cutlass doesn't have a access plate under the rear seat, and I don't remember seeing anything in the trunk either, but who knows, it's worth checking before dropping the tank. That hose coming out of the firewall with a 90 degree bent is the condensation drain for the HVAC, and should be pointing down and have nothing plugged into it. You can ignore that as a cause of your issues. Good luck, and if you need a picture of something else, or something confirmed, I might be able to do that for you. The car is outside on the driveway, and it's only -15 celsius. Hope you can figure it out soon! Quote Link to comment Share on other sites More sharing options...
1990lumina Posted December 6, 2009 Report Share Posted December 6, 2009 My '96 Cutlass doesn't have a access plate under the rear seat, and I don't remember seeing anything in the trunk either, but who knows, it's worth checking before dropping the tank. That hose coming out of the firewall with a 90 degree bent is the condensation drain for the HVAC, and should be pointing down and have nothing plugged into it. You can ignore that as a cause of your issues. Good luck, and if you need a picture of something else, or something confirmed, I might be able to do that for you. The car is outside on the driveway, and it's only -15 celsius. Hope you can figure it out soon! -24ºC windchill though!! Quote Link to comment Share on other sites More sharing options...
nebojsa_o Posted December 6, 2009 Report Share Posted December 6, 2009 My '96 Cutlass doesn't have a access plate under the rear seat, and I don't remember seeing anything in the trunk either, but who knows, it's worth checking before dropping the tank. That hose coming out of the firewall with a 90 degree bent is the condensation drain for the HVAC, and should be pointing down and have nothing plugged into it. You can ignore that as a cause of your issues. Good luck, and if you need a picture of something else, or something confirmed, I might be able to do that for you. The car is outside on the driveway, and it's only -15 celsius. Hope you can figure it out soon! -24ºC windchill though!! On 2nd thought, ask someone else for help. J/K, if you need something I can try anyways. And damn you Jeff, for bringing the bad news. Quote Link to comment Share on other sites More sharing options...
MonteCarloChick Posted December 6, 2009 Author Report Share Posted December 6, 2009 Boyfriend again. Assembled all the crap I took apart yesterday for the effing solenoid. Pulled plug #6, car has spark. Removed cap on passenger side of fuel rail behind power steering res. Pintle pressed all the way in, NOTHING. Cranked car with pintle all the way in, NOTHING. I'm not going to attempt the pump, the access plate I THOUGHT was there, was just a harness behind the driver side rear seat. Not to mention she has half a tank+ of gas.... New pump, harness, and strainer bought, waiting for a tow to the shop now. Could a weak/dying pump cause O2 sensor codes? Random/Multiple misfire codes? And could it cause a 0171 too lean code on only one bank? Quote Link to comment Share on other sites More sharing options...
AL Posted December 6, 2009 Report Share Posted December 6, 2009 Yes because the engine wasnt getting enough fuel to burn at 14.7:1 so it was running lean, causing the lean 02 sensor code and with how little fuel there was in there, it probably wouldnt be enough to spark it, causing a misfire Quote Link to comment Share on other sites More sharing options...
tornado_735 Posted December 7, 2009 Report Share Posted December 7, 2009 YAY you found the problem! Quote Link to comment Share on other sites More sharing options...
MonteCarloChick Posted December 11, 2009 Author Report Share Posted December 11, 2009 New fuel pump is in and the car ran like it did (if not better than) before! So while replacing everything else before the pump.. she got a nice tune up. And it really shows. Thanks so much again guys. I love you! Quote Link to comment Share on other sites More sharing options...
