Front Dash Speakers
The factory hood measurements above should get you close, but lining them up with the inner hood crease matters more than just squaring them off the outer edge.
flint_perch286 joined the community - Yesterday
Charlie Watson joined the community - Earlier
This thread is 15 years old.
