GnatGoSplat reacted to a post in a topic: `89 TGP joining the collection
GnatGoSplat started following '92 GTP, Why is it making this noise?
GnatGoSplat reacted to a post in a topic: '92 GTP, Why is it making this noise?
55trucker started following '92 GTP, Why is it making this noise?
Arthur joined the community
Those are not the same parts the 91-93 stuff did in fact have 3 ports. would they work? maybe? they look like they terminate at the check valve in the same place. -
