  1. Yesterday
  2. Schurkey
  3. 55trucker
  4. Last week
  5. crazyd
  6. crazyd
  7. GnatGoSplat
  8. 55trucker
  9. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  10. crazyd
    '92 GTP DIC - no fuel data?
  11. Earlier
  12. crazyd
  13. Schurkey
  14. bluecalais79
  15. crazyd
  16. Schurkey
  17. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
  18. SuperBuick
    Bluetooth Module DIY
  19. rich_e777
  20. Black92GS
  21. SuperBuick
  22. White93z34
    TRW Keyless Entry module
  23. Black92GS
  24. GnatGoSplat
  25. 55trucker
  26. primergray
  27. GnatGoSplat
  28. White93z34
