  2. crazyd
  3. Yesterday
  4. Apparently It’s called a spring plate. If I’m seeing things correctly, it seems like it’s used to attach to lower part of a spring compressor.
  5. I dont understand what the purpose of those wings hanging off the struts are. Curious why they are/were there.
  6. I have a 93 Cutlass convertible and after getting it out of winter storage a couple weeks ago I finally had an opportunity to put the top down and take it for a drive. Though I hear a slight clicking sound that seems to be coming from back by the pump, the top does not go down or up, and the pump doesn’t seem to engage at all. It seems that very little information is available. I looked for a fuse that would control the power to the pump and was not able to find one that looks like it is dedicated for that use. A relay is a possible problem, but I am having troubles finding that. Reading what I could find on this website, it sounds like a relay or relays could be back by the pump. I can try testing that, but because the top doesn’t move in either direction, I’m not sure if that will be the problem. If you have any ideas, please let me know. Thanks.
  7. Last week
  8. I’m hoping that somebody still sees this string because I’ve been reading it and it is very interesting for my problem. I have a 93 convertible and after getting it out of winter storage a couple weeks ago I finally had an opportunity to put the top down and take it for a drive. Though I hear a slight clicking sound that seems to be coming from back by the pump, the top does not go up or down, and the pump doesn’t seem to engage at all. Besides this string of ideas, very little information is available for me to find. I looked for a fuse that would control the power to the pump and was not able to find one that looks like it is dedicated for that use. After reading this information it sounds like the relay that I was trying to find is back by the pump. I suppose that I can try testing that, but because the top doesn’t move in either direction, I’m not sure if that will be the problem. If you have any ideas, please let me know. Thanks.
  9. Describe the *noise* you are hearing.......you say that this was heard when the original spring was still in place? Does the *replacement* spring still have the rubber pads glued to the ends of the leaf?
  10. The spring is installed and functional, the car a bit higher in the rear but I expected that. What I didn't expect is for the noise to return after about a day. I am wonder if it is the point where the spring contacts the plastic isolator and or where the the isolator sit in the bracket. Any ideas are appreciated.
  11. 55trucker
  12. 55trucker
  13. crazyd
  14. crazyd
  15. Schurkey
  16. 55trucker
  17. crazyd
  18. crazyd
  19. GnatGoSplat
  20. Earlier
  21. 55trucker
  22. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  23. crazyd
    '92 GTP DIC - no fuel data?
  24. crazyd
  25. Schurkey
  26. bluecalais79
  27. crazyd
  28. Schurkey
  29. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
