  2. GnatGoSplat
  3. Yesterday
  4. 55trucker
  5. I greased the outer tie rod and ball joint, why is it still making this noise? 20250502_104001.mp4
  6. Last week
  7. crazyd
    '92 GTP DIC - no fuel data?
  8. Earlier
  9. crazyd
  10. Schurkey
  11. bluecalais79
  12. crazyd
  13. Schurkey
  14. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
  15. SuperBuick
    Bluetooth Module DIY
  16. rich_e777
  17. Black92GS
  18. SuperBuick
  19. White93z34
    TRW Keyless Entry module
  20. Black92GS
  21. GnatGoSplat
  22. 55trucker
  23. primergray
  24. GnatGoSplat
  25. White93z34
  26. rich_e777
  27. rich_e777
  28. Interesting... didn't the manual show three ports on the exhaust manifold, and this shows just one? The plug wires come up from below there on 91-93, whereas it was relocated to the upper left in later years. That pipe probably wouldn't work due to interference with the plug wire routing.
  29. You're welcome. Something to investigate...these are 96 LQ1's. This is from a random Google search of 2 - 96 Monte Carlo Z34's. Looks like they have that same silver pipe on the front headers. Since we know the last year for the manual LQ1 was 92/93...and these are obviously automatic cars, maybe the same or very similar setup was standard on all 96-97 LQ1's by then. If so, this will help with the availability of possible parts prospects.
