94 olds vert reacted to a post in a topic: '92 GTP DIC - no fuel data?
White93z34 reacted to a post in a topic: '92 GTP DIC - no fuel data?
The Low Coolant light went on in all 3 of My CS, 2 94's, 1 96. The Coolant was not low. I just disconnected the wire at the sensor. I will change the sensor the next time the radiator is flushed, but until then, problem solved. - Earlier
Arthur joined the community
Those are not the same parts the 91-93 stuff did in fact have 3 ports. would they work? maybe? they look like they terminate at the check valve in the same place. -
Interesting... didn't the manual show three ports on the exhaust manifold, and this shows just one? The plug wires come up from below there on 91-93, whereas it was relocated to the upper left in later years. That pipe probably wouldn't work due to interference with the plug wire routing.
jiggity76 replied to crazyd's topic in Powertrain
You're welcome. Something to investigate...these are 96 LQ1's. This is from a random Google search of 2 - 96 Monte Carlo Z34's. Looks like they have that same silver pipe on the front headers. Since we know the last year for the manual LQ1 was 92/93...and these are obviously automatic cars, maybe the same or very similar setup was standard on all 96-97 LQ1's by then. If so, this will help with the availability of possible parts prospects. -
Awesome, thanks guys. Looks like I don't have the proper manifold to connect that pipe even if I had it. PO must have swapped it out.
its LQ1 5 speed only. Pipes 3, 20 connect to the exhaust manifold Pipe 17 connects to pipe 9 and the air pump, part 10 -
