  2. mdpierce8
    91 Grand Prix window motors
  3. 55trucker
    Cooling fan questions
    ^ Jeez Chris, you've got some arrangement I've not come across, even our previous '90 GP fitted with the V5 had no electrical fittings on the tail end of the compressor housing. Obviously the engine wiring harness goes to the switches? Another thought came to me, our friend in the Russian Federation has done a heart transplant to his GP, the powertrain is a Cadillac 4.9 out of a Brougham/Deville/Fleetwood, all which didn't make use of the V5.
  4. White93z34
  5. 55trucker
  6. Yesterday
  7. White93z34
  8. Megavolt-380
  9. 55trucker
  10. 55trucker
  11. Megavolt-380
    about 12v and below
  12. Megavolt-380
  13. Last week
  14. White93z34
  15. 55trucker
  16. 55trucker
  17. Megavolt-380
  18. Megavolt-380
  19. 95cutlass
    New to me 93
  20. what if i js took out the rear monoleaf and put some spacers would it work ? i mean the ride will obviously be bad but as long as it will actually drive like that i think i’d be fine with that
  21. Not really any of those as I recall. once upon a time someone made lowering leafs, pretty sure unless you find one of those your only option is DIY coil overs, Its been done here but honestly I was never into that so I can't speak to it
  22. jiggity76
  23. 55trucker
  24. anybody know the cheapest quickest way to completely drop the rear of a cutlass with the mono leaf suspension? ps no judging i recently picked a up a running/driving 92” cutlass supreme for 500 dolla so im trying to make something to scrape the floor
  25. jiggity76
  26. 55trucker
  27. Megavolt-380
  28. sclark
    Replacement Top Seals
