^ Jeez Chris, you've got some arrangement I've not come across, even our previous '90 GP fitted with the V5 had no electrical fittings on the tail end of the compressor housing. Obviously the engine wiring harness goes to the switches? Another thought came to me, our friend in the Russian Federation has done a heart transplant to his GP, the powertrain is a Cadillac 4.9 out of a Brougham/Deville/Fleetwood, all which didn't make use of the V5.
about 12v and below
White93z34 reacted to a post in a topic: Cooling fan questions
goldrush25 joined the community
dropping the rear of cutlass
what if i js took out the rear monoleaf and put some spacers would it work ? i mean the ride will obviously be bad but as long as it will actually drive like that i think i’d be fine with that -
Autopia.sa joined the community
White93z34 replied to 97cutty's topic in Brakes/Suspension/Steering/Wheels/Tires
Not really any of those as I recall. once upon a time someone made lowering leafs, pretty sure unless you find one of those your only option is DIY coil overs, Its been done here but honestly I was never into that so I can't speak to it -
U1rich joined the community
97cutty started following dropping the rear of cutlass
anybody know the cheapest quickest way to completely drop the rear of a cutlass with the mono leaf suspension? ps no judging i recently picked a up a running/driving 92” cutlass supreme for 500 dolla so im trying to make something to scrape the floor
55trucker started following Cooling fan questions
