  1. Last week
  2. crazyd
    '92 GTP DIC - no fuel data?
  3. crazyd
  4. Earlier
  5. Schurkey
  6. bluecalais79
  7. crazyd
  8. Schurkey
  9. I found a replacement plug for my air temp sensor on a junkyard car and am trying to get the wires out of it. I've got a round multi-tool for this that I got on Amazon that has five different tools on it but so far it looks like only the smallest straight-blade tool fits. I pushed the wires through the front of the replacement plug but that doesn't seem like the right way to do it.
  10. SuperBuick
    Bluetooth Module DIY
  11. rich_e777
  12. Black92GS
  13. SuperBuick
  14. White93z34
    TRW Keyless Entry module
  15. Black92GS
  16. GnatGoSplat
  17. 55trucker
  18. primergray
  19. GnatGoSplat
  20. White93z34
  21. rich_e777
  22. rich_e777
  23. Interesting... didn't the manual show three ports on the exhaust manifold, and this shows just one? The plug wires come up from below there on 91-93, whereas it was relocated to the upper left in later years. That pipe probably wouldn't work due to interference with the plug wire routing.
  24. You're welcome. Something to investigate...these are 96 LQ1's. This is from a random Google search of 2 - 96 Monte Carlo Z34's. Looks like they have that same silver pipe on the front headers. Since we know the last year for the manual LQ1 was 92/93...and these are obviously automatic cars, maybe the same or very similar setup was standard on all 96-97 LQ1's by then. If so, this will help with the availability of possible parts prospects.
  25. Awesome, thanks guys. Looks like I don't have the proper manifold to connect that pipe even if I had it. PO must have swapped it out.
  26. White93z34
    its LQ1 5 speed only. Pipes 3, 20 connect to the exhaust manifold Pipe 17 connects to pipe 9 and the air pump, part 10
